Webra T4-40
Old 08-03-2011, 04:33 AM
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Default RE: Webra T4-40
The engine in post 22 has one way valves in the crankcase and it supercharges itself ala YS, my T4 .87 had plates in place of those valves. MotorBoy has a T4 .87 with the supercharger valves.
Old 08-03-2011, 07:23 AM
earlwb
earlwb's Avatar
I think they just used a simple reed valve for it. One could likely make a reed valve unit if they wanted too.
Old 08-03-2011, 07:32 AM
gkamysz
My Feedback: (19)
gkamysz's Avatar
ORIGINAL: Reginald
The first Webra T-4's did have the arrangement like the engine from my collection. Later a conversion set was available from Webra so you could put the carb in the head.
Do you know why some of the T4-40 have the different arrangement?
Old 08-03-2011, 10:25 AM
Reginald
Forgot to mention, the engine on the left is the T4-80 of 1985 and on the right is the T4-40 of 1983.
The pics above are of the T4 14,314cc of 1980. The rotary valve was inspired on the Aspin principle. The fuel/air mixture goes through the crankcase.
The idea for this was to give some supercharging to the engine but that did'nt work out as expected so later engines got the carb directly into the head.
That HP VT-21 did have long vertical cooling fins and is pretty scarce to find today. Frankly, I do not have good memories of that big T4, flew it on a Telemaster.
Black goo coming out of the silencer. Very difficult to rebuild these T4's, by that I do mean the distance of the valve that is achieved with very thin shims and
on all the T4's Ive rebuilt these shims were badly worn to cigarette paper thickness.
ORIGINAL: earlwb
Nice pics of the T4 engines Reginald. I think you have the most ultimate collection of engines that I know that anyone has.
If I remember correctly, the T4-40 with the carb mounted directly on the head was for RC cars or trucks. Years ago, there was a push to get people to use 4 stroke engines in cars and trucks. For RC cars and trucks, OS marketed a .26, MECOA had a special VT-21 or 25, and Webra had the T4-40.
Old 08-03-2011, 11:58 AM
Motorboy
Motorboy's Avatar
ORIGINAL: Hobbsy
The engine in post 22 has one valves in the crankcase and it supercharges itself ala YS, my T4 .87 had plates in place of those valves. MotorBoy has a T4 .87 with the supercharger valves.
My engine T-4 .87 has 2 reed valve, 1 before crankcase and 1 after crankcase. Easy to start the engine.
One disadvantage: The weight is about same as a OS FT 160 engine and not so powerful.
Old 12-20-2018, 06:34 PM
  #31
Tanque
Tanque's Avatar
Originally Posted by gkamysz
Nothing about the way it looks says it's not production.
Here's mine.
I found one more on google images. Webra-Motoren
Sorry to resurrect this old thread. I'm new to owning Webra T4 engines but have been aware of them since Webra introduced them and have used
the Webra 40 RC "Blackhead " 1022 since the mid 70s and have many of them. I only acquired these because I recently purchased a model transmission
that uses a T4-40 as it's power source. I found and purchased the 2 T4-40s as spares but was unaware that there were variations of the engine. Looking
into the drum valve of these it is easily seen that they are substantially different and it obviously isn't a matter of simply reversing intake and exhaust components....
As others said in this original thread finding information on these engines is sketchy. If there are other threads or other references I'd enjoy reading them so any assistance would be appreciated.
Old 12-25-2018, 10:18 AM
  #32
Kmot
My Feedback: (24)
Kmot's Avatar
I would love to see what this transmission and engine are used in.
Old 12-25-2018, 11:50 AM
  #33
Tanque
Tanque's Avatar
It is intended for a tank, 1/10 ( perhaps 1/8 as well) scale. I do not know who built this transmission. I have others of different types that use a Webra .40 RC
'Blackhead'. This is the first I've seen made to use a Webra T4 type. I've used OS and Saito 4 cycles in other models before.
You may refer to an earlier thread to see the use of the Webra Blackhead. http://www.rcuniverse.com/forum/glow-engines-114/884441-rings-webra-40-blackhead.html
Jerry
Old 12-25-2018, 06:58 PM
  #34
Kmot
My Feedback: (24)
Kmot's Avatar
WOW! That is awesome looking! Thanks for posting the photo.
Old 12-27-2018, 12:49 PM
  #35
downunder
downunder's Avatar
You can find tests of the various T4's at Model Engine Tests
Old 02-25-2021, 10:01 PM
  #36
stevesak
My Feedback: (27)
FYI,
‘I came upon this thread trying to figure out which of my T-4 40’s to sell and which to keep. Both are new in box and have black belt covers. One in a red box, the other in an orange, and I remembered the main difference was that the intake and exhaust were switched on them.
Red box is part number 1044RC and says Webra T4/40
Orange box is part number 1043RC and says Webra T4/40 mit Heckvergasser
Translated is “with rear exhaust gasses”
Old 02-25-2021, 10:04 PM
  #37
Tanque
Tanque's Avatar
Originally Posted by stevesak
FYI,
I'll make it easy for you: Sell them both to me!!
Jerry
Old 03-04-2021, 05:45 AM
  #38
wolfiberkleidz
Default wevbra engie/ perry carb
Good day to all,
Please help me with this doubt I have
I have a webra engine and would like to restore for using it in an airplane, but tsome carb parts are missing, can I install a perry carburator whith out a pump?
will the perry carb work ?
many thanks
Old 03-04-2021, 10:31 AM
  #39
1200SportsterRider
1200SportsterRider's Avatar
If the Perry is the correct size it should work very well.
wolfiberkleidz (03-08-2021)
Old 03-08-2021, 06:02 AM
  #40
wolfiberkleidz
Many thanks. I appreciate it, stay safe
Old 06-01-2022, 06:30 AM
  #41
Dieter F.
Dieter F.'s Avatar
FYI,
Sorry, that´s wrong, "mit Heckvergaser" means "with rear carburetor" ;-) (Heck = rear, tail and Vergaser = carburetor)
