UMS Evolution Radial Care and Operation
#327
My Feedback: (43)
WA
RE: UMS Evolution Radial Care and Operation
Tom - There's a good 1/2 " between the cowl and the rockers. The plywood mount ring inside the cowl would not let the cowl slip over the engine. I cut about 8" off the bottom of the ring and it slipped right over. I can rig a way to attach the portion that I cut off to the cowl once it has been slipped over the engine or I might just leave it as it is. It attaches quite solid. The cut out for the exhaust was the only other thing I did. I did weight her and it came to 19.4 ibs. I have two large batteries, the glow plug unit and fuel tank to go. Should be around 22 lbs ready to go. Galen
#328
My Feedback: (62)
Galen, Sounds perfect. I bet you will be able to cruse at 1/3 throttle using a 10 to 12" pitch prop. I cannot remember, have you run your engine yet? If it flies like my Robin Hood 99 with the 9-90 in it you will be thrilled. Thanks for the info. -Tom
#329
CA
OK, Steve, this is your fault! I can't stand it any more so I ordered a 90" BH Corsair today. I'm sure it will be quite a while before I actually build the Corsair because of other projects on the table but at least I now have a goal and direction for my EVO 7-77 engine.
Roger
Roger
#330
My Feedback: (43)
WA
ORIGINAL: Maxam
Galen, Sounds perfect. I bet you will be able to cruse at 1/3 throttle using a 10 to 12'' pitch prop. I cannot remember, have you run your engine yet? If it flies like my Robin Hood 99 with the 9-90 in it you will be thrilled. Thanks for the info. -Tom
By the way , I appreciate you pointing me to this Waco. I think it will be a fun flyer.
Galen
#334
I was wondering about the bottom two cyl. after setting awhile (over night) the plugs fill up with oil, and before I start the engine for the next flying session I pull them out and clean them out by blowing out the oil and then relighting them with my flight box glo driver, and then put them back in and it runs great after that process, (I have some holes to access the plugs without taking the cowl off), not sure if there is a cure, or, is the oil content I am using too much? 9% right now til the home made stuff is gone and then I will be using the 7% I got at Toledo, any thoughts?-Steve
#335
My Feedback: (62)
Steve, You might be overoiling at the end of the flying session. Too much can flood those cylinders. Experience guided me to use the right amount (6-8cc) If there is no hydralic lock just start the engine as I do. I store it upside down, so by the time it is to start I am OK.
-Tom
-Tom
#336
CA
Hey Steve,
Thanks for taking the blame - I hope you know that was all tongue in cheek. I love the Corsair and after seeing Kevin's and your videos, I just couldn't wait to order one. The BH Corsair seems to be getting hard to find now and a lot more expensive. I'm not sure that BH is still in business but their Corsair is a nice one. It sounds as though the retracts with the kit need to be discarded and replaced but the plane is solid. I'll test the stock retracts first but everything I read indicates they are of poor quality.
Best wishes and good safe flying!
Roger
Roger
#337
Thanks Tom,
I believe you are Right I have been putting 10 to 12 or even 15cc, I guess just to make sure. another question is about how many flights should you fly before oiling the rockers again? 3-4 or 5? the same day? (I understand for the next day) they should be re-oiled, but is 4 or 5 flights in one session OK with only one oiling?-Steve BTW I have been using a good quality ATF (automatic transmission fluid), not sure if that makes a difference or not, but can use any other oil I guess?.
#338
the Corsair is Cool, I need to put a little more detailing on mine, my buddy Marshal ( the one in the video) built it did a great job, but I like more detail, if I had to do it over I would use the new Robart Electric retracts, I have 2 other war birds with the Lado electric retracts and they work flawlessly, with no hassles, I really like the electric retracts.-Steve
#339
My Feedback: (62)
Steve, A really good oil to use on the rockers is motorcycle chain or chain saw chain oil. It is made to stay stuck on the surfaces rather than being blown off. Works well! I now only oil about every ten flights. Occasionally it is wise to use solvent to clean away the old black oil and put fresh on. Hey you guys don't forget about my BH corsair shown early in the thread. The included retracts are really bad. I am using Lado rs333rb which have recently been strengthened. The protruding rod went from 5mm to 6mm and the gear that turns appears to now be steel. -Tom
#340
Good choice Tom, I thought about the chain saw oil but was not sure, also I have some additive I bought from the Toledo show to help stick to your bearings from Boca bearing co. but I tried some in my fuel and what a mistake I had a real sticky airplane when done flying for the day and was real hard to get off of the covering that I had on it, it was a real mess, I have not used it since, but that is good to know about every 8 to 10 flights thanks. I was about to mention your Corsair also to Roger he should check it out earlier on this thread looks very Cool How many flights do you have on it Tom? -Steve
#341
My Feedback: (62)
Steve, I have over 50 flights on that corsair! Way too much fun to fly. The flaps work well and do not balloon the plane when lowered. I do have the servo's on the flaps slowed way down though and they have two positions programmed in. -Tom
#342
CA
I had a Hanger 9 Corsair powered by a Zenoah G20 ei with a B&B header and a 15x7 3-blade prop that I flew for several years. That plane was great and had outstanding performance. Last year at our annual War Bird show, the plane decided to self destruct. The left wing broke off completely in a right hand turn. It was a structural failure, nothing broke at the joints but the wing failed at the mid point. The plane was completely destroyed and the engine crank was bent. I had the engine repaired by Ralph Cunningham and it now has a happy home in a Hanger 9 Fokker DVII. However, I still miss my Corsair and Iam looking forward to this new radial powered larger Corsair.
Roger
Roger
#343
CA
Hey Tom,
Do the Lado retracts just drop into the BH Corsair or does it take a lot of modification like the Robart retracts?
Thanks, Roger
Thanks, Roger
#344
the R-2800 P&W radial engine made top power near 3000 rpm. the reason for the gear reduction was to keep the prop from going super-sonic. the hugh paddle blade props had to absorb near 3000 hp at full emergincy power and if the prop went super-sonic all that power would go to waste therefore the gear box to slow the prop. the smaller engines such as the r 985 with a hd-30 prop made thier max power around 2300 rpm and that is just below super-sonic tip speed. this is the blatt sound you hear at full power tack off from the full size pratts.
#345
atf is for tranmissions not for model engine rockers. use a 50 wgt synthetic motor oil or 90-140 syn gear lube...it sticks to the rockers real well.
#347
ORIGINAL: fred985
#348
ORIGINAL: Heli-NuBee
Hey Tom,
Thanks, Roger
Hey Tom,
Thanks, Roger
#350
CA
One other question, what model Lado retract, 333RT or 333RB? I think it is the RB model but I would like to be sure.
