Fuel Pump Questions v2.0
Old 10-14-2011, 03:44 PM
captinjohn
Default RE: Fuel Pump Questions v2.0
We are sorry...
You are seeing this message because of one of the following reasons:
  1. Your session timed out.
  2. The server was restarted before you made a HTTP POST (posting a message, registering an account, login, etc.)
Problem #1:
You probably spent too much time and your session timed out. This is, however, rarely the cause of the problem because we implemented a session keep-alive mechanism to prevent this issue from happening. However, the server itself could have experienced some problems that prevented this mechanism to work as it should, and therefore we cannot completely rule out the possibility of this either.
You need to make sure your browser has cookies enabled. See below for instructions:
Netscape Communicator 4+:
    [*]Select "Edit" from the browser Menu bar[*]Select "Preferences"[*]Double click on "Advanced"[*]Verify that "Accept only cookies that get sent back to the originating server" is selected[*]Select the "OK" button[/list]
    Microsoft Internet Explorer 4+:
      [*]Select "View" from the browser Menu bar[*]Select "Internet Options"[*]Select "Security" tab[*]Select "Custom (for expert users)" security level and select the "Settings" button[*]Locate "Cookies" and verify that "Allow per-session cookies (not stored)" is enabled[*]Select the "OK" button on the "Security" window[*]Select the "OK" button on the "Internet Options" window[/list]
      If you already have cookies enabled and still experienced the problem, see problem #2 below for other possible causes.
Problem #2:
Your server experienced problems and was forced to restart. Restarting a server will erase all session data and our protective mechansim had no choice but to drop your HTTP POST because we had no way to identify you without valid session data.
Many forum administrators host their forums on shared servers, on which could have more than 200 sites hosted together. Sometimes the server has to be restarted because some badly written programs on other sites may drain the CPU/RAM and cause the IIS to restart itself. This is unfortunately an inevitable situation that many site administrators and its users have to face from time to time
Old 10-14-2011, 07:04 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Things must be working pretty good for you to be able to copy and paste that message into a post twice?
Old 10-14-2011, 08:29 PM
N429EM
N429EM's Avatar
ORIGINAL: Hobbsy
The regulators come with a check valve that pressurizes the tank using muffler pressure on a fourstroke and crankcase pressure on a two stroke and when you see the tank bulge, even one of those stiff walled Sullivans you'll see that there is plenty of pressure to regulate. Since the check valve traps the peak of the pressure pulses in the crankcase or muffler the pressure is considerable.
PS, it would not have been, ''hi jacking'' since it is the same topic.[8D]
OK, so, the regulators do help to increase the flow of fuel from a tank located further back than normal. Right?
Just not with a pumping action?
Oh, and Hobbsy, don't you have that backwards? Muffler pressure on a two stroke, and crankcase pressure on a four stroke?
Thanks, for all the replys, everyone,
EJ
Old 10-14-2011, 10:39 PM
r/c-beginner
umm im new to the hobby and thinking about buying a nitro r/c car of him but it wont start, dont want to buy it if i cant fix it. what could i try?
Old 10-14-2011, 10:48 PM
1QwkSport2.5r
1QwkSport2.5r's Avatar
ORIGINAL: r/c-beginner
I think you need to start a new thread in the car forum describing what kind of car and engine it is and the fuel/glow plug/starting system being used to get a better answer. Glow engines (or in the car world, nitro engines) need a healthy glow plug heated properly, fuel, air, and compression to run. Too much or too little of any of those will cause an engine to not start and/or run properly. There is no need for a fuel pump in a car engine since the fuel tank is almost always right in front of or right behind the engine.
Old 10-15-2011, 03:28 AM
  #31
Rudolph Hart
Rudolph Hart's Avatar
ORIGINAL: N429EM
ORIGINAL: Hobbsy
EJ
Hello EJ! a fellow sufferer i see,me too,i always get things back to front
Old 10-15-2011, 04:09 AM
  #32
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
No sir, I have it exactly correct, crankcase pressure from a tap on the backplate of a two stroke and muffler pressure from the stock pressure tap on a fourstroke. The tap on a fourstroke crankcase is strictly for a vent and should not be used for any other purpose. Actually I have a couple of older two stroke engines where the pressure tap is in the left mounting lug, I plugged them and put them in the back plate. There are two things of import to keep in mind when setting up a Cline or IronBay regulator, keep the check valve as close to pressure tap as you can get it and the same goes for the regulator body. The closer the regulator body is to the spraybar the more accurate it can read the demand. Having said that I have used a Cline on a Saito 1.30 twin with two 3" pieces of fuel tube on a Y and it worked perfectly. Don't buy into folks saying that the demand regulators won't work on an airbleed carb, the regulator doesn't know the difference.
Old 10-15-2011, 05:21 AM
  #33
w8ye
My Feedback: (16)
w8ye's Avatar
+1
Old 10-15-2011, 05:57 AM
  #34
1QwkSport2.5r
Based on my experience with a VP-30 and having it not work real well for my intended purpose, Would you guys say it would be better to use a regulator alone if I needed to have the tank 9" away from the carb's spraybar and have good reliability?
Those regulators are pricey, do they ever really wear out?
Old 10-15-2011, 11:36 AM
  #35
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Glow fuel is kinda hard on them but they still last two or three years. It was the policy at IronBay to provide at least one free replacement diaphragm.
Old 10-15-2011, 12:39 PM
  #36
1QwkSport2.5r
ORIGINAL: Hobbsy
Does it matter if they were dried and cleaned out after each use to prolong their life or is it like a firework - light the fuse and when its done its done? Not that it matters... I cant imagine the diaphragms being that expensive..
On my original question - Will a regulator allow me to put the tank 9-10" away from the spraybar and not need a pump too? I've got an airboat that needs to have the tank below and behind the engine (6" below and 3" behind). The pump I have does work, but the idle and midrange end up being too rich with the pump set where the top rpm doesnt suffer.
Old 10-15-2011, 12:49 PM
  #37
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
10" would be nothing. Mr. Cline recommended that a piece of fuel tubing be run from the inlet to the outlet to store the Cline regulator, same for the IronBay. Flushing it with Foggin Oil from NAPA would be a great preservative and easy to do.
Old 10-15-2011, 12:54 PM
  #38
1QwkSport2.5r
ORIGINAL: Hobbsy
10'' would be nothing. Mr. Cline recommended that a piece of fuel tubing be run from the inlet to the outlet to store the Cline regulator, same for the IronBay. Flushing it with Foggin Oil from NAPA would be a great preservative and easy to do.
Excellent. When I find a better .61 for my airboat, I'll get a regulator. A .46 doesnt have the snort to get my 7 pound hydrofoil airboat on plane.
Thanks for the info. I appreciate it.
