Cold weather which Glow Plug?
My Feedback: (26)
NM
Cold weather which Glow Plug? Iwent out to fly the other day and it was a bit cold, probably in the mid 40's, Iwent through 2 glow plugs and didnt get a full flight out of either of them. The died about half way through flight and where done for! Ihave been using Fox Hot plugs with idle bar, far over a year and havent had any issues out of them unitl now. What do you guys use for your glow plugs when the weather gets cold? Idont remember having any issues last year when it started cooling off.
RE: Cold weather which Glow Plug?
ORIGINAL: BT00561
Cold weather which Glow Plug? I went out to fly the other day and it was a bit cold, probably in the mid 40's, I went through 2 glow plugs and didnt get a full flight out of either of them. The died about half way through flight and where done for! I have been using Fox Hot plugs with idle bar, far over a year and havent had any issues out of them unitl now. What do you guys use for your glow plugs when the weather gets cold? I dont remember having any issues last year when it started cooling off.
G'day
There is an old saying in car racing circles - "cold and wet, bigger jet". Or in other words, in cold weather you need a richer mixture. You should not need to change the plug if it works well the rest of the time but you probably should make the mixture richer. Lots of burned plugs is usually too lean a mixture.
Mike in Oz
Mike in Oz
My Feedback: (264)
MD
ORIGINAL: BT00561
What type of failure are you talking about here?
I'm with Mike. I've never in seven years of running glow had to change plugs just from seasonal temp shifts. My cars run the same OS 8 in the snow as they do in those horrendously humid 105º southern summers, and have done for years. My plane, too, runs an OS8, and it will continue to do so when I fly in winter.
Fatten the mix up and it will stop burning plugs out. Every engine needs to run richer in the cold than the hot. Every engine. Even the one in your car. Our RC engines simply don't self-adjust for that, so they'll lean out unless we step in and do it ourselves.
The cold it self cannot ruin the plug, so it sounds more like a general tuning problem that glow plug problem. 40°F is not that cold, but there are several things happening, there is more oxygen in the air, the fuel runs a little thicker (especially with all castor fuel) and the engine runs colder etc.
The two first reason means that the needle should come out while the third may wrongly indicate a too rich setting. My guess would be that you have a little more nitro than needed for the compression setting and that the engine was running on the lean side, hence blowing the plug. Unless you're doing competions there is no real reason for tuning that close to plug faliure. So add a head shim or two or reduce the level of nitro (use a tach before and after to monitor the changes in performance). When it is actual cold, around freezing or below, you can wrap something around the cylinder to help keep the temperature up, but I don't think that was your problem here.
Cold air is dry and dense, so the engine will be gulping more of it. Hence the advice to richen up the needle. Once the engine is running I don't think the cooler air would make the engine run cooler, unless it's a very small engine.
For quicker starts, try a drop or two of Ronson cigarette lighter fluid in the intake. We used to squirt it in the exhaust for quick starts when flying Combat in the snow (the annual Frozen Finger contest, held the first weekend of the year IN CHICAGO). The engine kicks back something fierce when you turn the prop over, even when air temps were sub-zero.
Iskandar
Iskandar
It can and will. The colder air can remove more engine heat, which means if you don't wrap the head you won't warm it up enough. It's real bad with cars, sometimes in the dead of winter they'll get so cold they lock up entirely despite being run WOT through a combination of large, multi-fin cylinder heads and absolutely frigid ambient air. The sleeve contracts so much that the piston sticks in the pinch, and that's it. Not running any more, and sometimes it takes a rod with it.
Wrapping the heads is a given when running glow cars in the snow, I imagine it won't hurt aircraft engines either.
My Feedback: (26)
NM
I have some OS #8 plugs also and I run them in a couple of my engines. We only flew one plane the other day when we had the issue. I havent flown any of my planes in the winter time, since i usually go overseas for the winter, so this year is a first. I have had plug go bad from running it to lean, but didnt think about it the other day since a couple days before all the engines ran like a champ. So I will richen it up and give her another shot. Thanks guys for all your inputs. I really appreciate it!
IL
I've ran airplane and car motors in sub-zero temperatures. The kind of cold where your snot freezes upon the first inhalation through the nose.
I have never had a problem with fuel or glow plugs, nor have I made any changes other than needle settings to accomodate cold.
ORIGINAL: ArcticCatRider
