saito 120
TX
RE: saito 120
You ought to down load the Saito Notes thread located at the top of this topic. You might find some good info on your engine. Sounds like your engine is not up to par. Check valve clearances first. If they are okay well you probably have a bad ring or worse problems. If you go into the engine I would replace the bearings while you are in there.
Good luck,
Chip
Good luck,
Chip
