what is this 0,061 glow
MN
RE: what is this 0,061 glow
I believe it is an early G-Mark engine made in Japan. I think it was distributed by Cannon R/C in the 90's along with the .03 engine, sadly both companys are gone. I bought one on E-bay awhile back and would certainly like any more info on it to.
Hi,
Think you may have it right, certainly says made in Japan on it, the only logo is on the back plate.
The letter M with an arrow above it. Too small to see on my rather poor photos.
Is this the logo on yours?
Will try and post another two photos.
The part I can't figure is the copper strip running round the back of the cylinder and going
into cylinder block. What is it for?
ORIGINAL: airraptor
man that is a super small carb. can you take the muffler off and then post som better pics?
Thanks guys for correctly identifying it, much appreciated.
Its an early version of the G-mark .061(quite rare), the latter model had a different muffler. Here are some comments from RCG:
http://www.rcgroups.com/forums/showthread.php?t=1245225
http://www.mh-aerotools.de/airfoils/...allengines.htm
G-Mark .061 (1.0 cm³)
Manufactured in 1980
This engine uses a nice cast crankcase and a steel cylinder. These cylinders were also used for a flat twin and a 5 cylinder radial. The G-Mark company also produced a larger .15 single and a .30 flat twin, again using some identical parts. All G-Mark engines were well designed, but probably too expensive to manufacture. I have flown this engine in a small Piper J-3 Cub.
They had a nice .12 twin based on the same engine and a 5 cylinders radial (.30):
http://modelenginenews.org/cardfile/gm12.html
