Installed an MPI MX-9900 Super Glow Driver, glow plug not getting hot?
Hello out there!
I have just installed an new MPI MX-9900 Super Glow Driver, everything seems to work find. Battery is fully charged, I programed the MPI unit as per instructions. The LED light comes on at 1/4 throttle & the LED light goes out over 1/4 throttle. My problem is the glow plug doesn't get hot or turning red. I'm thinking the glow should get red hot like if you had an 1.2 battery wired directly to the glow plug. Can anyone give me some input on my problem. Any idea's would be greatly apprecated!
Gerry
Gerry
RE: Installed an MPI MX-9900 Super Glow Driver, glow plug not getting hot?
I think the ones that use the reciever battery pack can be set up to use a smaller current to save on batteries. You may need it to be red hot to start, but I doubt you need it that hot to improve the idle.
ORIGINAL: Sport_Pilot
Gerry
ORIGINAL: fizzwater2
how do you have the wire connected to the metal case of the engine?
The wire is under the motor mount bolt. But just to let everyone know, the problem was a bad toggle switch. If you look at the diagram, the toggle switch has three post, the two outside post are (on) and the center is (off). The switch that came with the unit only would go "on & off or so I thought! But there was a defect in the switch to where the switch wasn't making contact to the (on) post in the switch. So I ran to Radio Shack, bought a new switch and now I have a red hot glow plug. I'm a happy camper now..after working on this thing for a couple of days, I'm ready to fly!I'm hoping it'll be hot enough to start my engine without running an dummy glow plug to us a external glow driver. So thank you guys for your input & help!
Gerry
