Where Can I get A Prop Extension 4 Saito?
I'm trying to stuff a Saito 200Ti into an 83" Brian Taylor Spitfire cowl W/O any of the engine protruding.
I can accomplish this if I set the engine back about 1".
Does anyone make prop extensions for that type (threaded) of prop shaft?
I've "googled" it but I haven't been able to come up W/anything that I would trust on a 4-stroke engine.
RE: Where Can I get A Prop Extension 4 Saito?
I used a unitracts extn on a saito 180 and laser 200v (although the 200v was only in a test stand) and they worked well. I had no isses with the props comming off as most model 4 strokes these days dont kick like they used to. Laser engines dont use a locking nut of any kind and never throw props. as the 200ti is a twin i would say its even less likely to throw a prop than a big single
How long was the extension? I may need one that is about 15mm for a Laser 150. I just want to be assured this extension thing won' t cause any issues with respect to wobling or shortened bearing life.
I checked Unitracts web site but I was unable to find any pictures.
