Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Glow Engines
Reload this Page >
cleaned an engine in prestone and it blackened ... what to do ?
Old 05-27-2012, 04:40 PM
superocket
Default cleaned an engine in prestone and it blackened ... what to do ?
I know this can happen ...
prestone possibly too hot ...
is there any way to remove this oxydation ?
thanks
Supe
Old 05-27-2012, 04:47 PM
ThumbSkull
My Feedback: (57)
ThumbSkull's Avatar
Default RE: cleaned an engine in prestone and it blackened ... what to do ?
You may have used 50/50 already diluted and that can make it worse.
Not much you can do. Put it in service under a cowl or send it for powder coat.
Old 05-27-2012, 05:17 PM
fiery
Bead blast it carefully and it will look better than new.
Old 05-27-2012, 05:51 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Try boiling it in Vinagar?
If you boil an engine in Prestone it will discolor the aluminum.
Old 05-28-2012, 05:31 AM
Iflyglow
My Feedback: (79)
Iflyglow's Avatar
ORIGINAL: w8ye
The idea is to simmer the engine in (undiluted) prestone, and it works perfect. I do probably 10 engines a year for friends, and I have never ever had a problem.
Old 05-28-2012, 06:14 AM
Phoenixangel
Phoenixangel's Avatar
You can use a brass tumbler for polishing ammo brass, you have to take everything apart and be sure all the sand is cleaned out of absolutely everything before reassembly. Depending on what polishing sand you choose, you can polish to a mirror shine or rough metal. You can use walnut or pecan shell instead of sand. This will only remove the oxidation but none of the metal itself.
Old 05-28-2012, 10:38 AM
earlwb
earlwb's Avatar
Well I would just chalk it up to experience and put the engine back together and use it.  Of course the ugly engines never wear out and run really good too.
Old 05-28-2012, 02:14 PM
superocket
IFLYGLO , I sent you a PM
thank you for your replies gents
Old 05-28-2012, 02:35 PM
huck1199
huck1199's Avatar
This won't help now, but I like to use Dawn Power Disolver before they get badly baked on oil.  I do it right on the plane every few flights.
Old 06-16-2012, 05:03 AM
jetpack
jetpack's Avatar
I have used this and an various brushes starting with brass and then a stiff nylon detail brush. Stainless brushes and this cleaner work well together but watch your edges and it might leave scratchs.
It's water rinse so it flushes out really well and leaves no residue if your careful. Works great with a scotchbrite pad. The compound really helps remove oxidation on brass without touching so it must be a little acidic.
Barkeeper's Friend is also a good product. Look for it in the sink cleaners at the grocery store, same with the copper cleaner. It's like Comet sink powder but different in the respect it etches aluminum nicely to a factory shade.
If you want to do it right it takes elbow grease and taking the whole motor apart. I don't know of any other way without masking and grit blasting.
One note about grit blasting, I personally would oil soak the cases afterwards to lift all the powder out of the aluminum pores with some good penetrating oil. I have done this and its amazing how much aluminum is left in the pools of oil.
Old 06-16-2012, 05:41 AM
Dan Vincent
That Dawn Power Disolver is great stuff but make sure you rinse it off with water as it will keep on working and can mess up aluminum engine cases if not stopped with water when clean.
It's almost as good as that engine cleaner Davis Diesel used to sell. Wish I could get some more of that stuff.
Old 06-16-2012, 07:51 AM
357ross
ORIGINAL: Phoenixangel
Phoenixangel, would you mind explaining this process a little further? For example, what to use for abrasives, ect.? I have the equipment to do this, and would never have thought of it. Thanks.
Old 06-16-2012, 08:36 AM
airraptor
My Feedback: (66)
I clean most of my engines in heated antifreeze. i had an engine turn dark like that and that is because i let it cool over night in the antifreeze. it doesnt hurt the engine at all and if anything it will help it run ever so slightly cooler.
