Help, Prop size 3-blade OS200FS Warbird
Reply
Old 07-22-2012, 03:47 PM
Rate1
Rate1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Help, Prop size 3-blade OS200FS Warbird
Guys help me out.
First of all, I understand that one should try out different props to find the performance wanted. However the cost for a CF scale prop is high and buying 10 different props seams a tad unnecessary with all the combined experience found here at RCU. I'm instead hoping for some advice to guide me to a starting point in the 3-blade CF scale prop market for my engine.
This will be my first warbird project, ESM Corsair 74" approx 16-17,5 lbs, and will put on my OS200FS non pump with a Perry vib pump. I wish to use a big 3-blade prop on it for scale reasons and still be a good performer. I found the Biela 18x10 3-blade Corsair scale prop that I'm hoping I could use. My engine is all new and has never been runned so i know little about it.
Q: Do you think the Biela 18x10 3-blade is too much for this engine?
Q: Which 3-blade scale prop do you think I should go for?
Q: What fuel offer the best power for this engine and could the engine be damaged?
Q: which pitch is commonly used on 74" warbirds? Been flying aerobats earlier I'm used to 6-8 pitch.
OS Recommended props: 16x12N-15, 16.5x12-14, 17x10N-13, 18x6W-12 and 20x8.
In addition, I found a general rule of thumb for props; going from a 2-blade to a 3-blade reduce the diameter by 10%, hence the 20" 2-b becomes a 18" 3-b. I have also found a recommendation that if adding another blade one should increase the pitch with one unit as the additional blade is shading the blade next to it.
Q: does that mean the load will stay the same as the prop is shading itself, or does that mean that you increase the pitch to avoid shading and also as a consequence get bigger load?
If going from 2-b to a 4-b one is recommended to reduce the diameter by 15% and again increase the pitch with one unit, meaning that a 20x8 2-blade would equal a 17x6-7 4-blade. I understand that for the optimal performance one should stick with 2-blad props within the model world due the effect of Raynolds number.
If increase the pitch one should decrease the diameter.
I'm looking for warbird style flying and would be happy with 7500RPM'ish as I understand it would be a good number for this engine which has good torque but not so good revs. I am ready to increase the percentage of nitro if that would help me. Any advice?
Rate1 is offline
Old 07-22-2012, 06:10 PM
Hobbsy
My Feedback: (101)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Help, Prop size 3-blade OS200FS Warbird
http://www.zingerpropeller.com/_2_blade_.htm
Here is a chart to help you some, I'll be back.
Another for engine to prop size
http://www.zingerpropeller.com/Convert.htm
Hobbsy is offline
Old 07-23-2012, 01:21 AM
Rate1
Rate1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, these are usefull charts. To bad it is indicating that the Biela 18x10 3-blade might be a notch too big for this engine.
Rate1 is offline
Old 07-23-2012, 08:19 AM
blw
blw's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Please tell Capt Morgan that you always end up with some percentage of guesswork and experimentation. However, the undesirable props you check out on the Corsair can be used somewhere else one day.
blw is offline
Old 07-23-2012, 10:20 AM
Hobbsy
My Feedback: (101)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rate, that shaded blade business is part of an Old Wives Tale that was de-mythed many years ago. Since the blades are constantly moving forward into new air, there is no shading/ineffeciency etc. When it comes to power absorbtion a well chosen 3 blade is more effecient.
Hobbsy is offline
Old 07-23-2012, 03:05 PM
Rate1
Rate1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys, well too much or not that darn prop is so beautiful I just got to have it anyway. I can always just hang it up for display untill I find a motor big enough for it. Order placed.
I got an APC 18x8 for first running of engine and for maiden flight anyhow.
Rate1 is offline
Old 07-28-2012, 11:51 PM
Emil The Swede
Emil The Swede's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have tested some props on my OS-200S. The engine was not fully broken in at the time, but it will give a hint
3-blade (MA) 16X8; 9000 rpm; 7,4 kg pull
3-blade (MA) 16X10; 8200 rpm; 8,2 kg pull
2-blade (xoar) 18X6; 8100 rpm; 8,6 kg pull
2-blade (xoar) 18X8: 7300 rpm; 8,3 kg pull
I have the 3-blade MA 16x10 on my ESM Spitfire, but I will try the Fiala 17x8. Maybe that the 18x8 3-blade will work, but probably not. Since I see you come from Sweden, you can find Fiala props at www.aircpro.com.
Another thing to remember with the OS-200S is that it do not like RPM:s above 8400, it is the exhaust-valve-spring that is to weak. You will know that if the engine runs great on the ground, but "bludders" in the air, when you pass the magic rpm:s. In that case you have to get an intake-valve-spring (it is harder) and put it on the exhaust. There where Per Olof Linder in Sweden who discovered the error and the fix. I have tried it on mine and it works great.
Emil The Swede is offline
Old 07-29-2012, 03:11 AM
Hobbsy
My Feedback: (101)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www3.towerhobbies.com/cgi-bin...?&I=LXCW95&P=Z
The intake spring is 20mm in length with a 6mm ID the exhaust spring is 18mm in length with 6mm ID, the above link is the longer/stronger intake spring.
Hobbsy is offline
Old 08-02-2012, 12:06 PM
Emil The Swede
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I found that Xoar also have som 3-blades, both 17x8 and 18x8. Not scale, but very good looking. Ad the Hamilton Standard Prop Decal and you are close...
http://magnumrc.com/xoar-m-5.html
magnumrc.com/hamilton-standard-prop-decal-set-p-242.html
Old 09-18-2012, 10:28 AM
Emil The Swede
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rate, How did it go with the prop size? Can you share the test result?
