Enya 60 XLF Bearing noise
Hi,
Just after a bit of advice. I have purchased a used Enya 60 XLF with geared pump. The engine had been run when I purchased it and I have run it on a test stand. However when I rotate the engine by hand I can hear a bit of what sounds like bearing noise from the front bearing. Is this normal for an engine to have a bit of a rubbuing type noise when you turn it over?
RE: Enya 60 XLF Bearing noise
No the bearing noise means the bearing is bad. You'll need to replace both the front and rear bearings.on the crankshaft. it isn't a big deal to replace the bearings. Since the Enya engine has a removable front end, you can pull the front end off without disturbing the piston to cylinder fit. Thus making it even easier to replace the crankshaft bearings.
