YS 1.10FZ Prop Nuts ???? HELP!
My Feedback: (15)
FL
In yet another RCU classified "deal" I purchased an YS 1.10FZ for my newly recovered Funtana S90. The engine showed up missing the outer prop nut.
Anyone besides central hobbies have a set? I'd like both as the inner is pretty beat and looks like the previous only had vice grips in the flightbox. Central shows them in stock, but after I paid nearly $20 for 2 nuts and a washer, 5 days later they tell me they do not have them.
Anyone? I have a Funtana ready to fly, but I refuse to run a big 4 stroker without the outer lock nut.
RE: YS 1.10FZ Prop Nuts ???? HELP!
Have you checked with your local screw products (industrial) outlet? It would not have the mating capabilities of the stock nut but might work until Central gets them in. Also DuBro makes a spinner nut for them which I have, at least for my YS 70.
Ernie Misner
Ernie Misner
My Feedback: (15)
FL
ORIGINAL: Ernie Misner
Ernie Misner
Ernie Misner
The YS 1.10 uses a M8x1.0 thread diameter & pitch. I have a database of neary 300 glow engines and it's the only one that uses a 1.0 pitch with M8 diameter.
My Feedback: (15)
FL
ORIGINAL: SeamusG
Here's a parts list &explosion ...
I guess I can put that project back into mothballs for a while. Jeremy at YS said it may be weeks and weeks before they get anymore.
Do you know anybody in Greeley, CO? There's a set in a store there (Things With Wings) - BUT - they will, under no circumstance, ship.
If you do a member search and narrow the search by city "Greeley" you will find 90 RCUmembers that live there. Idon't know anyone personally - but - you may ...
You might start a thread looking for a Greeley contact. Just thinkin' out loud.
We can solve Taz's problem. We cannot solve a parts distribution problem.
Oh yea - Ithink that Isaid that the FZ 1.10 is the ONLYengine that uses a M8x1.0 crank shaft. Everything else is M8x1.25.
Good, it's just a parts distribution problem, thanks. I was worried there might be a manufacturing slowdown or worse in this economy. It was sad to see companies like Webra go under.
Thanks for the info,
Ernie Misner
Ernie Misner
Great idea! ..... and it will be hardened and up to the job if it will mate properly without the Tru Turn parts on there. Or heck, use a Tru Turn spinner unless it throws the balance off too much.
Ernie Misner
Ernie Misner
My Feedback: (48)
MI
ORIGINAL: Cobra1
How about a true turn spinner adaptor. It looks good and serves a second purpose as well. They must make one. Just a thought.
My Feedback: (15)
FL
I took a peek at my FZ 70 and I AM using the TruTurn nut and washer along with a Dubro spinner nut. Works great.
Ernie Misner
Ernie Misner
