If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 7 of 7
Thread: Saito 90TS
  1. #1
    Join Date
    Aug 2010
    calgary, AB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Saito 90TS
    I boughta NIB 90TSlast summer on line, never had a Saito before. It has two red wires included in the box with spade type clips on the end, to fit over the glow plugs I assumeand one black wire with a ring type connector on it, not sure what it"s for. Are these typically included with a saito engine? I am thinking of using a glo driver setup for it. What is a good type to use?
    Tiger Flyer #75
  2. #2
    Moderator w8ye's Avatar
    Join Date
    Dec 2001
    Shelby, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Saito 90TS
    The glow plug wires are typically supplied with the multiple cylinder engines.
    I have all the current smaller multiple cylinder Saito engines and I do not use a on-board glow driver with them.
    Attended the CutFinger Institute of DirtNap University for years but never did graduate....
    Recipient, Mangledhand award August 2008
    Club Saito Member #7
    Original AMA #31261
  3. #3
    SrTelemaster150's Avatar
    Join Date
    Feb 2012
    Brasher Falls, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Saito 90TS
    ORIGINAL: swify
    I boughtΒ*a NIB 90TSΒ*last summer on line, never had a Saito before. It has two red wires included in the box with spade type clips on the end, to fit over the glow plugs I assumeΒ*and one black wire with a ring type connector on it, not sure what it''s for. Are these typically included with a saito engine? I am thinking of using a glo driver setup for it. What is a good type to use?
    You can wire the plugs in series if you have an ajustable glow driver in your flight box power panel. Just hook 1 glow plug to + & the other glow plug to - & adjust the amperage to 3 amps. (green on the scale)
    You can also use 2 seperate clip-on glow drivers if you do not have a power panel.
    Club Saito #785 - FA91S, FA-115, FA150, FA180, FA180HC/BBC, FA200TI, FA300TTDP: All with CH Ignitions CDI/Glow fuel
    SIG BH #42
    - 1/3 Spacewalker, Rascal 110
    CUB BH #231 - Wings Maker 1/5 J-3 Cub
  4. #4
    Join Date
    Dec 2003
    Lambertville, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Saito 90TS
    I have one of these engines running on a glo driver, it will only run on one cylinder, checked valves, glo plug, all ok. I can't put it back into a plane in the current state. I never had any issues with my os 160 twin. so I am a little confused
  5. #5
    Hobbsy's Avatar
    Join Date
    Dec 2001
    Colonial Beach, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Saito 90TS
    Low Speed needle too rich.
    Minneapolis Moline G 1350, 585 cubic inches, 141.4 hp, 9.7 GPH fuel use, 4.75 inch bore, 5.50 inch stroke
    CR==15.3 to 1
    Max pull== 14,178
    Front tires==11x15
    Rear tires 24.5x32
    Weight==12,550
    Club Saito member #5
  6. #6
    mike109's Avatar
    Join Date
    Jul 2004
    Dubbo, New South Wales, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Saito 90TS
    G'day
    I have a 90TS and it runs like the proverbial Swiss Watch. I use fuel with 10% nitro in it. I do not use on board glow as it is in a Cub and it is quite accessible so I just use two pocket glow drivers. I did have to adjust the low speed needle quite a bit during the running in process.
    Saito engines generally come out of the box with the low speed needle set quite rich. OS engines come out nearer to the final setting. Because of this, many OS owners never adjust their low speed needles and put up with an engine that runs OK but which could run better. I had this argument with a friend at the field last week. He never touches the LSN on his OS engines and proudly told me so. He also told me that it was normal for his engines to "load up" and need to be "cleared out". If I could just get him to adjust the LSN I am sure these little problems would be behind him.
    Cheers
    Mike in Oz
    \"I just had no control. Must be the radio.\" Club Saito #597 Kadet Brotherhood #66
  7. #7
    Join Date
    Feb 2012
    Brasher Falls, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Saito 90TS
    ORIGINAL: mike109
    G'day
    Saito engines generally come out of the box with the low speed needle set quite rich. OS engines come out nearer to the final setting. Because of this, many OS owners never adjust their low speed needles and put up with an engine that runs OK but which could run better. I had this argument with a friend at the field last week. He never touches the LSN on his OS engines and proudly told me so. He also told me that it was normal for his engines to ''load up'' and need to be ''cleared out''. If I could just get him to adjust the LSN I am sure these little problems would be behind him.
    Cheers
    Mike in Oz
    You can lead a man to knowledge but you can't make him think.
    SIG BH #42
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
