Best replacement for a worn OS40FP
RE: Best replacement for a worn OS40FP
ORIGINAL: aspeed
Or try it and see. Maybe a lower pitch prop may be needed or longer lines, but I don't think the difference would be noticeable with the different sleeve. Just don't run it too long in case the cyl. wears and then you can't really use the piston/liner in the original motor.
If he wants a 4-2-4 break the differance is significant. TheMagnum is set up for higher revs and no regare with a 4-2-4 break. These engines will four cycle at lower RPM's then if they break into a 2 cycle run on the upline, they will either stay in atwo stroke run at way too fasta speed, or they will take way too long to break back to the 4 cycle mode.
There are people who reportsleeves to make normal sport engines run in 4-2-4 mode and the result is aless powerfullengine but more torque, especially when runningin 4 stroke mode.
I was always on the quest for more speed, so never bothered with the 424 thing. I have a Twister and an FP to try out maybe this week though. Some guys used pipes on stunt planes, do they do the 424 thing? I can't imagine that. I think a sleeve would have to be dropped in the case a bit to get the lower timing required (without a pipe anyway)
ORIGINAL: jeffie8696
I have tested the FP/GPA swap before and after and found no appreciable power change.
ORIGINAL: aspeed
ORIGINAL: aspeed
I think a sleeve would have to be dropped in the case a bit to get the lower timing required.
The pipe on a c\l stunter does the opposite of that on a fast plane, it artificially holds the revs down, but when the engine loads up in a climb the pipe holds the same revs as in level flight, so the engine does not slow up.
The V60 was never popular as a piped engine in C/L Stunt. It was used as a muffler engine in the 80's. I used it as such and most of the upper National competition group did so in the same way. A few east coast flyers tried the V60 on a pipe. It was not a success because it is loop scavenged and timed too low.
The OS 40 VF and OS 46 VF were the standard in 90's piped Stunters. Randy Smith must have sold tens of thousands. I had four for two models. Hunt and Pappas used OPS 40's and other Pattern style stuff, they were also not very popular.
The 4-2-4 break is sometimes used by some pilots using pipes in Stunt. The typical set-up is a near-constant rpm runs with little change.
Chris...
Chris...
