If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 13 of 13
  1. #1
    Join Date
    Jan 2013
    Spring Hill, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Super Tigre .90 Flying Weight..
    I have a Great Planes Cap 580 Embry Riddle, and installed this engine on it.She came in at 7.4lbs, and was wondering if this engine would be enough for 3D flying.
    I'm interested in vertical performance.
    Thank you in advance.
  2. #2
    Join Date
    Mar 2002
    Little Elm, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super Tigre .90 Flying Weight..
    Depends on what you expect with 3d flying. To me this plane is too heavy for the g90 to fly the typical 3D I am used to seeing. But with the right prop it could do some limited 3D, and would have pretty good vertical.
    Ed
    \"there are fighters and there are targets\"
  3. #3
    Ernie Misner's Avatar
    Join Date
    Jul 2002
    Tacoma, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    On my g90 a mac's header and mousse can muffler cut weight and really made it come alive.
    Ernie Misner
  4. #4
    mrbigg's Avatar
    Join Date
    Oct 2004
    Streator, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You'll probably be alright. Mine likes an apc 15x4W.
    Smooth, like Keith Stone.
  5. #5
    jeffie8696's Avatar
    Join Date
    May 2007
    Muscatine, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Can you give us some tach readings with that engine and prop ? Iwould guess it should be very good.
    Club Saito # 677-Team Boca Bearings-Star Collectibles Muscatine-Glowhead Brotherhood #19
  6. #6
    mrbigg's Avatar
    Join Date
    Oct 2004
    Streator, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I can't as my tach got destroyed by the lawnmower.[:@] Had the engine on my Mojo which weighed 6.75 or so wet and it had unlimited vertical. This was running 0% fuel also. Put a Saito 100 on it and and with the same prop, vertical is about the same. The Saito has instant throttle response when running 33%, (not the best with 0%). Way better for 3D work. A Xoar 15x6 is recommended for the 100, and might work good on the .90. Spool up would probaly be better also being as it's lighter.
  7. #7
    Moderator
    Join Date
    Apr 2002
    Champaign, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Do not use a 15" propeller on your SuperTigre 90-size engine. A 13 x 8 would be a good prop, or maybe a 14 x 6 or 7. You want the engine to turn up near 12,000 RPM when you have it leaned to just rich of peak RPM on the ground. A 15" propeller will be too much load, and will never allow the engine to run well. Throttle handling will go out the window with that large a propeller, plus you won't have good power.
    Bill Baxter, Manager Hobby Services/Futaba Service/North America
    3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
    Service Phone: 217 398-0007
    Email: hobbyservices@hobbico.com
  8. #8
    mrbigg's Avatar
    Join Date
    Oct 2004
    Streator, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Tried a 14x4W and the .90 didn't seem to like it. I'll try a 14x6 regular blade when I put it in another plane.
  9. #9
    Moderator j.duncker's Avatar
    Join Date
    Jun 2004
    Sailing in the Eastern Caribbean
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: c550th
    Not enough engine to handle 7.4lbs. for 3D.
    A good prop for it is an APC 14 x 4 W at least that is what I used to run on mine.
    The dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible.
  10. #10
    Join Date
    Jul 2002
    Tacoma, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My ST 90 on a mac's header anc mousse can really did come alive. That std. muffler really sucks.
  11. #11
    Join Date
    Feb 2005
    Midland, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ernie's correct!
    The S.T. 90 really wakes up with a tuned can. Not sure if it will 3D your plane like you want, but you will like the engine alot more.
  12. #12
    Join Date
    Jul 2002
    Tacoma, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The can cured the "ST rich midrange" too.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  13. #13
    1QwkSport2.5r's Avatar
    Join Date
    Oct 2006
    Cottage Grove, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Ernie Misner
    The can cured the ''ST rich midrange'' too.
    The ST midrange problems can be cured with the stock mufflers too. It takes about 2 gallons or more to have enough run-time on it to be able to run the spraybar straight in. Until then, the spraybar ends up needing to be about 45° off from straight in to get a good transition. Mine transitioned great in that position until about 2 gallons where it started getting lean in the midrange. Putting the spraybar back to factory position, and Presto! A perfectly smooth instant transition after a 60 second idle. Pretty nice.
    Although a bigger carb and a bigger muffler does yield more power, they aren't needed to get a SuperTigre to transition well.
    GlowHead Brotherhood #3
    Real engines use glow plugs.
    R.i.P Jacob Wetterling #11 10/22/1989
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
