GMS ENGINES
My Feedback: (110)
PA
GMS ENGINES
anybody running any gms engines. they came in 40 and 60 size,where sold by tower hobbies for awhile any info would be great......good.bad..etc..............thanks...... ........RON
RE: GMS ENGINES
Did you mean the GMS engines? They were low cost engines, that would work well if you got a good one. But quality control was a little hit and miss and usually the engine would be fine, but the carb would have issues. I played with a GMS 1.20 engine for a while and it worked OK after I swapped out the remote needle valve unit for a better one. The engine also ran well using a OS carb too.
RE: GMS ENGINES
Hi fellows: I have 3 GMS .47 engines. The 4th one I lost on a fly away trainer. My experience with these engines has been just fine, BUT a lot of work has taken me away from doing a lot of flying with the other 3 new engines. The fly away .47 really ran well, and had a nice bark to it when going to idle. I have also read where there were problems with the carbs on some engines. Believe the basic engine is well made, and if coming with a good carb, you will have a good flying experience. Having 3 new ones, I will have the ability to move the carbs around if one or two seem to be faulty. I also collect other named engines such as the Kangke SK .50 and JBA .46 engines. The prices are worth the gamble to see if they actually run. The .39 JBA really is a screamer. It pulled my Royal trainer ok, but the verticle flight was missing; so have installed the JBA .46. This engine is still putting out black colored oil after going through the test stand run in according to Dave Beirke's instructions. Suspect it will take another half gallon of fuel burn to finish the break in while flying a a rich two cyle setting.
Have any questions? [email protected]
My Feedback: (110)
PA
RE: GMS ENGINES
yeah thats them GMS engines. just wanted to know if they were any thing good about them. i guess there ok as long as the carb works or swap it for an os carb..........thanks........RON
RE: GMS ENGINES
One of the GMS 1.20 engines I ran with a Perry Carb on it. The engine ran really well with a Perry carb. OS carbs are nice but very expensive. But the Perry carbs are reasonably priced and work well though. Also the Brison standard sport muffler for Webra 1.20 engines fits the GMS 1.20 too. I was trying different carbs and stuff out which is why you see the old original GMS remote needle assenbly still on the engine.
My Feedback: (110)
PA
RE: GMS ENGINES
i put an os .46 carb on it....better but not running right.......rich lean.uneven. this is a .47 GMS engine. there have been a host of problems with these engines. i finally was ready to give up on it and thought,i wonder if a idel bar glow plug would do any good. i had one from three years ago. sitting in my box. it was a k&b i think. well what a difference it made.......smooth low idel, transition from idel to full better than ever before and no to rich or lean feeling either. in fact it runs as good as my os .46 fx now. with a 11x6 prop she screams. this idel bar plug made all the difference......believe me...........RON
TX
RE: GMS ENGINES
That;s the kind of plug SIG recommends for the Avaistar engine the import. I found it idled very low and ran well. It was all in the plug for that engine. Not surprised at the same performance on the GMS.
RE: GMS ENGINES
If any Chinese carb has problems to run,try to cut LSN about up to one millimeter(If LSN has some taper on length) .Mostly LSN cant restrict enough or another say,travel of barrel cant match with LSN profile.Also make sure LSN O ring has better seal.So, that cut will help to have more consistent run.
RE: GMS ENGINES
Huge thread on the .47 years back. Someone identified a misalignment of the brass insert where the fuel nipple goes into the carb thus blocking fuel flow. Mine was only sightly misaligned and I drilled it out and flushed it out. I got rid of the remote needle valve and now the engine seems to run okay. I have it on my old trainer.
RE: GMS ENGINES
ORIGINAL: Uncas
RE: GMS ENGINES
ORIGINAL: MJD
This was an oft reported problem.. many were fine, but those that weren't were a PITA. Depending on what rpm and thus what fuel flow demand, they might or might not suffer from starvation at WQT. Guys that used bigger props and kept the rpm down probably ran into less problems statistically. If the fuel flow was sufficient the engines ran fine.
ORIGINAL: Uncas
