OS 300 Twin Problems
Reply
Old 09-06-2012, 01:45 PM
morganflyboy
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default OS 300 Twin Problems
Hello Everyone
I am having a problem with my O.S. 300 Twin, I go thru the priming procedure like the manual says to. Throttle fully open, choke applied and 2 counter clockwise rotation and the 2 clockwise rotation to prime the cylinders. When I spin her over there is so much raw fuel coming out of the pipes it is coating the tires on both sides. I gave the Air Bleed Screw a 1/2 of a turn counter clockwise which according to the manual should mix more air then fuel, I am using an EDI on board glow system to the glow plugs and all is working. I am at my wits ends with this thing, I need some advice and help on this one.
Thanks Morgan [&o]
morganflyboy is offline
Old 09-06-2012, 02:51 PM
P-40 DRIVER
P-40 DRIVER's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: OS 300 Twin Problems
what is your fuel tank height? , sounds like your syphening fuel. Tank shoud be centered on carb and fuel lines high looped. Even that may not be enough to prevent syphening.
P-40 DRIVER is offline
Old 09-11-2012, 09:11 AM
Cobra1
My Feedback: (42)
Cobra1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You do not say if it starts after the priming. When I prime my 300 twin fuel also comes out of the pipes. I then set the throttle to idle, attach the glow driver and lightly prop backwards against compression and it starts right up. Does it start?
Cobra1 is offline
