US 120 Lite and a OS FT-300
CA
I'm putting a OS Ft-300 on my well worn US 120 Lite and I'm kinda worried about ground clearance.Would a 18x12 MAS prop be enough prop for this combo?Anything over a 18" prop is pretty close to the ground.
Thanks for any advice Jim.
CA
RE: US 120 Lite and a OS FT-300
TFF,it's already had a G-38 and CRRC40 on it.When I got the airframe I cut the firewall back about three inches,so I don't think it will be nose heavy.The FT-300 is lighter than the G-38,not much lighter/but still lighter.I think this engine will be easier on the airframe too!!!It's smooth as silk.
Thanks for the input Jim.
If you want more ground clearance for a larger prop, put larger wheels/tires on the landing gear or modify the landing gear.
My Saito FA300TTDP turns a 22X8 Zinger @ 7100 RPM static. It would take about the same HP to turn an 18X12 @ 8100 RPM.
Oops I entered the wrong data. 8100 sounds OK to me. Th e18X12 should work OK.
CA
Thanks guys,thats what I wanted to hear.Planes almost ready to go,just have to recover a few places on the fuse that were damaged when I lost a wheel in flight and ripped out the landing gear.
Later Jim
Later Jim
