Magnum XLS-52
#152
RE: <span class=
I also noticed that the throttle is not linear, basically I get no response from 1/4-1/2 throttle, then it seems to wake up. Kinda makes landing in high wind more difficult.
Anyone else experiencing this???
#153
AZ
RE: <span class=
ORIGINAL: wildnloose
This is a fairly basic trick, but there is so very much information to be aware of that it's really hard to remember it all!
#155
RE: <span class=
The answer is: Either change the geometry of the throttle linkage (to offset the servo arm to nearly 90 degrees at full retard throttle position) or to program some opposite exponential if a computer radio transmitter is used.
#156
RE: <span class=
I have the ASP 52 - I believe it's pretty much the same engine. The slow speed mixture is veeery sensitive - turn it fractions at a time and you should get there after playing around with a tankful on the ground.
The motor goes like hell, though.
Mick.
Mick.
#158
RE: Magnum XLS-52
I received my 52 XLS for $50 almost brand new. At a Hobby People that I worked at for a little extra money. The engine was offered to me because a customer that bought it stated that an airleak was causing the motor to run to lean. I brought the motor home put it in a Super Sportser the first thing I noticed was that the muffler was spinning and was lose from the engine. From there the engine was a nightmare. It had great power until I found the big problem. The set screw that holds the carb on the motor was striped. And causing the air leak. Anyway I'm going to love my 52 XLS right in the trash. Not really I'm going to send it in to Magnum. Let them try to fix it then sell it. Then go buy a good motor like an GMS 47 or ST 45. Good luck. Mac.
#159
MD
RE: Magnum XLS-52
Don't forget; as you go up in nitro content, your fuel economy goes down.
I personally run 5% or less nitro Morgan Omega, and an Enya #3 glow plug on my Rossi .45 w/ APC 10x6 prop. I consistently get 15,300-15,600 rpm on the ground with this combo.
#160
RE: Magnum XLS-52
ORIGINAL: mac4taz
#161
RE: <span class=
I've tried 3 different magnum 52 carbs on my Magnum 52, and it still has a rich midrange!
With the low speed needle about 5/8 of a turn open, it is almost too lean on the idle end, but still goes rich in the midrange.... (top end screams!)
I kept getting deadsticks from flooding out the plug during transition. I went to a K&B idle bar plug as a last resort (had an OS 8 in there before) and that at least keeps the engine running dependably. It sure would make a lousy 3D plane with a lousy midrange though.
Are others having this problem?
The low speed needle is very blunt on the end. Would someone please try putting one of these needles in a drill or lathe and try making more of a taper on the end???? I may do that in time, but can't at the moment.
Ernie
Ernie
#162
RE: Magnum XLS-52
My 52 XLS hand started right out of the box. It usually starts on the first or second flip. You can get a Pitts style muffler from Hobby People for around 22 dollars and it works great. No leaks at all and no power loss. Mine screams while going vertical on my Global Super Decathlon 52/61. By the way a great flying plane if you beef up the landing gear. Also seal the edges of the trim if you don't want it comming off the first time you get hot fuel on it.
