Sullivan flex tank experience?
Reply
Old 11-01-2012, 06:50 PM
ululi1970
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Sullivan flex tank experience?
I am considering a sullivan flex tank for a 1/2A warbird. The space between the firewall and the next former is less than 3'. I can fit a 2oz tank, but I'd like to have a little extra fuel. The sullivan slant flex tank 4oz is advertised
to be deformable and can be reshaped with a heat gun. Any experience/suggestion? I am planning to pu a .15 engine and would like to fly ~ 6 min with some fuel to spare...
Thank you
ululi1970 is offline
Old 11-01-2012, 07:19 PM
blw
Moderator
blw's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Sullivan flex tank experience?
I've had problems with larger flex tanks. Poor fit on the stoppers and holes for brass tubing. They leaked.
blw is offline
Old 11-02-2012, 06:19 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hayes has a nice little 3oz tank. What I like about Hayes tanks for small models is that the stopper assembly doesn't weigh as much as the engine..
Hayes 3oz specifications (copied from a retailer's website so no guarantees on accuracy):
Capacity: 88 cc (3 Oz.)
Height: 47 mm (1.85")
Width: 38 mm (1.50")
Length: 76 mm (3.00")
Weight: 18 grams (.75 Oz.)
I like 3oz for sport .15's and 4oz for .15's with a bigger appetite for fuel, 2oz is okay on sport engines when you're stuck for space but I prefer that size for .09-.10.
MJD is offline
Old 11-02-2012, 06:29 AM
j.duncker
Moderator
j.duncker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have used the Sullivan flex tank in larger sizes where I had unusual tank vaults and they worked OK.
j.duncker is offline
Old 11-04-2012, 05:28 AM
ululi1970
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: MJD
Height: 47 mm (1.85'')
Width: 38 mm (1.50'')
Length: 76 mm (3.00'')
That unfortunately is too long. The space between the firewall and the next former is only 2.75''. I wonder if adding a 1 oz tank of top of a 2 oz tank is feasible. Any downside?
Old 11-04-2012, 05:37 AM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: ululi1970
Quote:
ORIGINAL: MJD
It will work, provided you have enough muffler pressure to force fuel from the lower tank to the upper tank. I suppose you could feed off the bottom tank and pressurize the upper tank but you might lose some pressure doing it that way since you would essentially have two vessels you're pressurizing instead of one.
Those tiny tanks are cheap enough, it might be worth trying just for the heck of it. It should work, but how well depends on your specific application.
1QwkSport2.5r is offline
Old 11-04-2012, 09:03 AM
w8ye
Moderator
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Sullivan white stoppers don't hold up more than a season for the rubber gets too soft and leaks. Flex tanks themselves held up OK for me using Dubro stoppers.
If a Flex tank is allowed to rub back and forth against something hard like hardwood, it will rub a hole through the tank eventually, But it might take a couple hundred flights to do it?
I say all this but the truth is, you should re-do your tank every year or so anyway with a new stopper and metal lines as well as clunk line. Be sure to check the tank for abrasion.
Even the metal lines through the stopper can wear out though you don't think of them moving. The metal will fatigue and crack inside the stopper and cause air bubbles.
w8ye is offline
Old 11-06-2012, 03:24 AM
ululi1970
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: w8ye
At this point, I will try to use two Hayes tank stacked...
Reply
Display Modes
