The Weirdest use of Glow Engines. is this for real?
Found this contraption on ebay, and can hardly believe the story is true. What would be the advantage, or thinking behind using glow engines to lower flaps on the space shuttle. Evidently it is supercharged, which would probably be needed at the high altitudes. I wonder if any of this actually carried over onto the actual shuttle. Seems like a failure ready to happen. [X(]
http://www.ebay.com/itm/EXTREMELY-RA...item5898c32c80
Can you think of any other weird uses of model engines?
Rod S
Rod S
RE: The Weirdest use of Glow Engines. is this for real?
A fine example of overcomplexity and gross expenditure to solve a problem that could be dealt with by other means!
I tried to find the car engine powered cordless screwdriver from Tool Time on the 'net with no luck. (I think it was a driver.. been a while).
I call BS. anyone can put NASA stickers on a "machinist project". Why would NASA release such an item? they would have destroyed it rather than let someone have it that easy. It has a walbro carb which probably will not work well with glow fuel. It doesn't have a starting system. how would you turn it over? It would be like trying to push start a car in first gear with the clutch engaged. The RGB would be geared down quite a bit.
Weird uses? Some WW2 emergency raft ditching equipment had a kite to fly an emergency radio antenna high up so the signal could be heard farther away. For calm days they had a provision, use an ignition model engine mounted to the kite to "blow" it up in the air. Not very successful.
ORIGINAL: Ram-bro
well it sold for 4495.00
I don't know if it's an actual NASA item or not, but it seems well machined. Why in the world use glow engines? Too unreliable, especially vibrating at Mach one or two. A couple good outrunners and lipos would do the job.
NASA probably did have that engine built to fly a drone at high altitudes for some project they had going on. The supercharger is the key to it as you would need a supercharger to help feed the engine air at higher altitudes. The supercharger is also difficult to machine as it has to be very tight on the tolerances and rotors inside too. Using glow plugs is not a problem as they can simply use a onboard glow ignitor system to ensure the glow plugs stay heated up as needed. Glow plugs wouldn't have the RFI noise emitted off of them like spark plugs and ignition systems would have and thus they would have a more clean radio signal for sending commands and having the drone return data too.
The trick is that NASA wouldn't just build one engine for a project, but they would have several made. So there ought to me more of them out there too.
Lipos ... if available back then... could they handle the low pressure and temperature?
Anyway, that lump looks genuine, to me.
Isn't Nitromethane a sort of "chemical oxygen" ? (is that tautologous?)
That could be handy for an engine in a low-pressure environment.
A drone would make more sense than something to do with flaps. But, 20cc to fly a drone? With $20 "toy" engines (1970's)? For the effort they put into this, they could have machined their own engine. I agree running on glow could have some advantages with receiving a clearer signal from a drone, and four engines may keep vibration down. They did have small chainsaw type engines back then which would be easier to modify, and could be run on glow.
I can see it now... after the shuttle lands a fella comes out with a bottle of spray cleaner and paper towels (the $50,000 dollar ones) then cleans the castor oil 'goo' off! lol
This reminds me of the story of the high dollar ink pens developed to function in zero gravity. The Russians used pencils... Don't get me wrong for I'm really 'into' this kind of stuff but sometimes you wonder what those nerds are thinking!
My Feedback: (24)
I have followed this seller on eBay for years. He has had some of the most amazing collectible engines for sale. I am always stunned by his collection he has sold off over the years. If it's from ToysTopHobby I totally believe it.
Pencils writing can be erased and smeared. NASA wanted to review all notes and writing and did not want them to erase it!
Chances of this being incorporated into the shuttle as a backup system are somewhere between zero and none. Can only imagine it an april fools joke (maybe at NASA since the listing on e-bay is not April).
Does not take an rocket scientist to see this is about as useless an option as any for any system on any space vehicle. Any other flight control system you know of in space (or aviation) using an internal combustion motor over say, hydraulic, pneumatic, electric, or cable?
ORIGINAL: Sport_Pilot
IMO its the supercharger that tells me it is a scam. Just doesn't work with a two stroke engine.
ORIGINAL: Flight Risk
There's definately a supercharger on that thing, and I have seen superchargers sold for 2-stroke model engines. In this case it would be needed to bring pressure up to normal ground levels. And there is too much expensive engineering in it to be a scam.
The NASA engine does look cool, but I too doubt it was really made to be used on any space vehicle or anything beyond a model airplane.
With the budget that NASA has, Ican't see them using something as unreliable as a glow engine on a multi million dollar space shuttle, And, Idon't think the shuttle had flaps, only elevons and a split rudder that also acted as a speed brake when it split. Correct me if Iam wrong.
John
John
Did the shuttle have flaps?
NASA has built hundreds if not thousands of radio controlled model aircraft over the years. It is much cheaper to flight test a model than a real plane with a pilot inside. NASA also crashed a lot of radio controlled planes too.
