Stripped threads on OS 46AX Engine Head
#54
MI
RE: Stripped threads on OS 46AX Engine Head
+ 1 ONYOURSIX same thing at the field when some one needs a new glow plug and you tell them the COST right on the back of the
PACK !!! and they say I canget one from H/K for $5.00 THENGOHOMEANDORDERONE I was selling it to them for the same thing
I paid for it !!!!! should of added $1.00 to it !!! CANTWIN R/L
#55
Hmm...that looks like that the insert has an outer thread that's screwed into the head (and glued additionally).
That's not the best solution but will probably work.
A better way for this is an insert that has an outer shape like an upside down "T" with the shaft of the T shorter than the flesh from the head
so that an screwed in Glowplug will fasten the insert additionally. This has to be made with an tight fit to the head and secured with an pin from above.
Regards,
Holm
Regards,
Holm
#56
See Post #7 Timeserts. They have a shoulder so they don't screw in too far, and they expand when screwed in. They aren't too expensive either after the initial shock of the first kit purchase. $13 for 5. I have also seen a head in my shop somewhere that had a knurl on the brass insert. It looks like it was pressed in from the top, but may have been cast in too. I can't remember what motor it was from right now. I think the original poster did pretty good on his repair in the end.
#57
Using some fine grit paper or emery cloth you might try smoothing any sharp edges on the inside of the head. Perhaps not a big deal but would be more critical on a gas engine that runs at higher temps.
#58
The brass plug installed in an aluminum head may change the heat requirement of the engine. The smaller the combustion chamber the more effect it will have. Brass will hold the heat far longer than the aluminum it replaced. If by chance you seem to have a harder time adjusting the carb especially if the needles seem fussier or the engine runs hot try a colder plug the brass insert may be raising the cylinder head temp just enough to give you fits. We had a piped JETT .25 that blew a plug right out of the head threads and all. The fellow may have over tightened it. We used a brass plug and it would not run consistently on the recommended Merlin plug. It was either to rich and would not peak out or if it did it soon would show signs of overheating. Tried hotter plugs and it got worse went to a colder plug and it ran fine. Tried that plug in the other Jett .25 (because it was locally available not like the Merlin) and it just did not work. We replaced the head over the winter and had to go back to the Merlin plug. Not very scientific but the only difference was that insert.
Dennis
Dennis
#59
I often wondered if an aluminum head/button was the best to use. A steel, or brass, or ceramic one may give better characteristics. Sounds like the brass holds the heat in better. Brass may improve the idle on some motors, or have some good effect.
#60
@aspeed: No, not meant it this way. I meant to insert the insert with the shoulder from bottom, from the piston side. This way the Glowplug
fastens the insert trough pulling it to the top. No outer thread on the insert (bad for the thermal contact).
Regards,
Holm
Regards,
Holm
#61
ORIGINAL: tiffitech
Regards,
Holm
Regards,
Holm
Dennis
#62
A Timesert might work from the combustion chamber side. The insert kit has a counterbore included. Still, the washer from the plug wouldn't be sealing on a flat surface at the position it needs, much like a Helicoil. A Timesert from the top looks like about the best to me because it spreads the bottom of the thread much like a rivet, so it will seal and lock too. A plug like the original poster ended up using is ok too if it doesn't move.
#64
@Proworn & aspeed: This isn't my idea, I have a book where this is illustrated, will search that book and make a picture. (B. Krause, Modellmotorentechnik). This Book is about Model Engines and the repair of them.
@Propworn: You have the exactly the thread length of the glow plug as flesh, this is enough for that job. No Problem for the combustion chamber shape,
I have a lathe, just press the insert in, mount the head in the lathe and resurface the Chamber shape, that's all.
I've got an as new looking Bluebird engine a year ago with an stripped Glowplug thread and I wanted to repair it this way.
Before I could do this, a friend came with an Helicoil kit and so I repaired it using this. Haven't run this engine jet.
I do have had bad experiences with Helicoil inserts on Motorcycles, saw more than one stripped out coil in the past (not my bikes) and so I'm
prefer the old fashioned way with an bush type insert. I can't look for that book before saturday, so please be patient.
Regards,
Holm
Regards,
Holm
#65
ORIGINAL: tiffitech
Regards,
Holm
Regards,
Holm
Dennis
#66
It seems to me that you know all things. You know all about me, my machines, what I'm done and what not, how to trust books you don't ever read, in short: you know all.
The sentence "Oh my Good" gets now a new meaning for me...
Regards,
Holm
Regards,
Holm
#67
ORIGINAL: tiffitech
The sentence ''Oh my Good'' gets now a new meaning for me...
Regards,
Holm
Regards,
Holm
Through all these years I have been an active participant in the model aircraft hobby. So yes I can claim a little first hand knowledge on the subjects we are discussing. I am not saying what you have seen in the book cannot be done and most likely has been done but it is not close to being the best solution to the problem.
This video I am turning a cylinder for a 1/4 scale Kinner Radial
[youtube]http://www.youtube.com/watch?v=bWJ9HChgBBQ[/youtube]
This is my cnc mill cutting the link rods for the same engine.
[youtube]http://www.youtube.com/watch?v=aYVm-bBwDWE[/youtube]
#68
I agree with Propworn regarding the co efficient of heat expansion of the different types of metals and the effect that would have on a brass bush pressed into a aluminium head. It is a fact that can not be disputed.
It is not a good idea. Like i have said before a heli coil would be the best way to repair the head.
I have been a first class machinist for 25 years and could quite easily set up the 46AX head in a lathe and machine it to accept the bush. But my experience tells me that isn't the best way.
A "T" bush with the head of the bush inside the engine is definitely not the way to do the repair and is just asking for trouble.
Reading something in one book and taking that for gospel is also not a good idea. You can't believe everything you read is the best way.
As for not using heli coils because you have seen them pulled out on other equipment? Well you have to be very rough to do that. That would not happen under normal conditions, unless the repair was not done correctly.
I quite often insert heli coils into aluminium products as part of the original manufacturing process, because it much stronger than threaded aluminium.
#69
Does anyone remember when a lot of guys were drilling a 2nd hole in motorcycle heads, heli coil, and installing a compression release, or Jake Brake??? What a funny sound they made and would slow you down going into a turn without locking up the rear tire. Oh, can't you just see a 50cc gasser on a down line and hit the Jake Brake?.....
#70
I don't want to get CNC equipment at all, there are friends here with such things ( I'm a programmer/electronican in my profession).
I own a simple german made, 60 years old mechanican late, grinders, a machine saw, a precision drill press, self made WIG and an indusrial MIG/MAG welder, spot welder and some other stuff. Enough for me.
As for the thermal expansion difference of aluminum and brass: Every brass or bronze bush in a conrod is falling out when it is getting hot?
Helicoil is the cheapest way to repair a stripped head, that's all.
Regards,
Holm
Regards,
Holm
#71
ORIGINAL: tiffitech
Regards,
Holm
Regards,
Holm
Bud you do what you want. Good luck to you. Just quit coming off as an expert when you know nothing of what you speak. Your last quip about connecting rods confirms what I suspected all along. I am one of the eight machine repair personnel in the connecting rod department at Essex Engine Plant in Windsor Ontario. If you even had a tiny bit of sense you could figure out first of all the press fit and area of contact makes up for the difference in thermal expansion when using aluminum alloyed connecting rod. On top of that most connecting rods are not aluminum but some ferrous alloy which has a lower co-efficient of expansion than the bushing. Let me know if you need this explained in detail I think the others get it. You are absolutely, beyond a shadow of doubt one of the most ill informed wrong thinking people I have ever had the chance to converse with. Not worth wasting any more time on. I hope no one is naive enough to take any of your advice seriously. Now as a great man once said "Go away little boy you bother me".
Dennis
#72
hmmm...
as i told you guys already that i got the head back... i put it back on the engine today...i know that there is a gasket that comes in between the engine head and the engine... is it the one in dark brown/copper color seen in the engine head underside photograph that i earlier posted? i think that is the gasket but i couldn't remove it easily..i didn't tried too hard since i dont have a spare at the moment and so didnt want to damage this one... i think its stuck in the engine head gasket groove due to old castor oil
anyways... so i put the head back...@aspeed: before putting it back i installed the glow plug on the head to check if it was flush or not... it was not
i tried to start the engine for more than thirty minutes trying at different throttle openings and needle valve settings including those on which the engine would always start but i couldnt start it....
Q- Could it be becuase of the glow plug not being flush with the engine head due to lengthier glow plug hole now? it is at least 1mm short at the moment I think i need a longer reach glow plug now as suggested by MrCox? does OS make it? if not which brand to use?
Q- i dont think the engine head gaslet is leaking but what is the best practice hear for these gaskets?
#73
Talk about arguing over nothing really, I would just put in a plug and run the damn engine, I bet it will run fine the way it is now
#74
If it doesn't start, see if it is holding the compression for at least a few seconds first. If it isn't leaking away you are likely ok. Most long reach plug motors that I have run fine with the 1mm shorter plug. I only had trouble running with a shorter plug on a .10 size motor, but it did run, although the idle was real bad. The head insert could be faced off 1mm, or a long reach plug used. Is your plug burned out? I don't know what brands of plugs are available over there. Here we use K&B 1L, Fox long med. or hot likely. Maybe a Rossi or Picco may be easier to get there. Enya and OS are the medium reach though, so I would get a long unless the head is modified back to a medium reach. It sounds like a dead plug to me though. The gasket is really more of a shim for adjusting the compression ratio. As long as it isn't damaged or torn it should be similar to the way it was.
#75
@aspeed: I removed the glow plug and put my finger on the the glow plug hole... by rotating the prop almost to TDC i could clearly feel the pressure on my finger tip... when i removed my finger air came out with pressure... i repeated this but this time i kept my finger on the hole for at least 5-7 seconds(clocked)... upon removing the finger slowly i could still feel pressurized air escaping from the the hole...
The glow plug is fine... checked it twice during the start up attempt... its an A3 type from OS...will check if any of the above glow plugs are available here..im sure i should be able to find at least one or two of them...
there is this one thing i feel which is out of the ordinary though... when i rotate the prop through the TDC with the glow plug removed, instead of feeling a slight/no restriction at the TDC it feels like the prop is passing through a notch internally... also i experienced the engine getting stuck at TDC when i was cranking it using the starter motor which previously never happened i.e. getting stuck at the TDC - the engine does eventually crank on if i do it by hand afterwards but again its a bit hard... i was thinking could it be because of bent piston pin or conrod deformation or bent crankshaft/conrod pin? it should be smooth through the TDC with a single restriction, right?
Thanks!
Thanks!
