os-60
Reply
Old 12-19-2012, 05:32 AM
rye
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default os-60
hi guys
i have a old os -60 that is new in the box with the valve that is close to the prop is there a remote valve that i can put on or can i change the carb to the new angle back valve, thanks
rye is offline
Old 12-19-2012, 06:03 AM
MetallicaJunkie
MetallicaJunkie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: os-60
yes....leave the main needle valve on the original carb set rich, and you can use a remote needle.
MetallicaJunkie is offline
Old 12-19-2012, 06:37 AM
luvtoav8
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: os-60
If it is truly "new in box" you would probably be better off to sell it to a collector and use the proceeds to buy a modern .61. Lot's more power and parts availability.
luvtoav8 is offline
Old 12-19-2012, 06:59 AM
NikolayTT
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: os-60
.... depends .... there might be more power but as well a shorter life of the new ones is also on the 'menu'...
NikolayTT is offline
Old 12-19-2012, 07:18 AM
rye
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: os-60
hi
which back plate and needle valve should i use
rye is offline
Old 12-19-2012, 07:47 AM
daytonarc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: os-60
This should work for you.  You can mount it wherever it is convenient with the 2 mounting holes.  http://www3.towerhobbies.com/cgi-bin...?&I=LXGCV3&P=Z
daytonarc is offline
Contact Us Archive Advertising Cookie Policy
