If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 18 of 18
  1. #1
    Join Date
    Feb 2011
    Burlington, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    O.S. 70 surpass looses rpms at full throttle.
    Hi all.
    I have a O.S. 70 surpass 4 stroke that I bought on ebay (probably not the best place to buy a reliable engine).
    The engine seems to run and idle well. However, the engine rpm will peek at about 90% throttle.
    When I push the throttle the extra 10% to full throttle, the engine rpms are reduced by 300 to 400 rpm.
    I am using a new glow plug, and have adjusted the valves twice. i have also tuned the low and high speed settings as best as I can.
    Can any one help me understand why I am loosing rpms at full throttle?
    Join Date
    Apr 2006
    Attunga NSW, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: O.S. 70 surpass looses rpms at full throttle.
    G'day Mate,
    It's probably lean, richen 1/4 turn, if it's on a plane, lift the nose vertically, & make sure the RPM's don't drop.
    Then fly it, if it looses RPM in the air, throttle back & land & richen some more, until it runs without loosing RPM's.
    Cheers
    Good Flyin Mate. Keep Thyne Airspeed up, lest the ground arise & smite thee,
    Allan.
  3. #3
    Join Date
    Feb 2011
    Burlington, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    alan0899
    thanks for the tip. I have tried to richen and lean the fuel mixture. the engine acts the same regardless if it is running lean or rich.
  4. #4
    Join Date
    Oct 2002
    1000MIGLIA CITY, ITALY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    IMO:
    To make 'like new' one OS 4 stroke is quite easy.
    -Buy the 2 main bal bearing and replace them .
    -Buy one piston ring and replace it .
    -clean all the engine before remount it, and not lose to clean the valve conduct and valve polishing .
    You'll find again all the lose power .
    I ALWAYS THINK POSITIVE
    BUT I FLY NEGATIVE.
  5. #5
    ronwc's Avatar
    Join Date
    Jan 2002
    LARGO, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've notice it too, probably valve float so I don't push it.
    Ron - AMA 1025 - Largo, FL
    Roaring Top Lipo Batteries - Authorized Dealer
  6. #6
    Hobbsy's Avatar
    Join Date
    Dec 2001
    Colonial Beach, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My guess is that the LowSpeed needle is too lean, that renders the HighSpeed needle ineffective above a certain point. Richen the LS needle about one half turn then try to peak the HS needle.
    Minneapolis Moline G 1350, 585 cubic inches, 141.4 hp, 9.7 GPH fuel use, 4.75 inch bore, 5.50 inch stroke
    CR==15.3 to 1
    Max pull== 14,178
    Front tires==11x15
    Rear tires 24.5x32
    Weight==12,550
    Club Saito member #5
  7. #7
    Moderator w8ye's Avatar
    Join Date
    Dec 2001
    Shelby, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Hobbsy
    Bingo!
    Attended the CutFinger Institute of DirtNap University for years but never did graduate....
    Recipient, Mangledhand award August 2008
    Club Saito Member #7
    Original AMA #31261
  8. #8
    Join Date
    Feb 2011
    Burlington, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the tip rosnik,
    I am not sure what you mean by this statement, can you clarify?
    "-clean all the engine before remount it, and not lose to clean the valve conduct and valve polishing ."
    thanks
  9. #9
    Join Date
    Feb 2011
    Burlington, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the tip Hobbsy,
    I did adjust the low speed idle for the best idle speed, but I will try to richen the idle screw and see if that helps.
  10. #10
    Hobbsy's Avatar
    Join Date
    Dec 2001
    Colonial Beach, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Always be willing to sacrifice a few idle rpm in favor of the best transition. Take car, Dave
    CR==15.3 to 1
    Max pull== 14,178
    Front tires==11x15
    Rear tires 24.5x32
    Weight==12,550
  11. #11
    Moderator blw's Avatar
    Join Date
    Mar 2004
    Opelika, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The low speed needle is for engine running like the high speed needle. The low speed is more important to engine performance than the high speed needle, imo. Too rich causes problems all over the place, and too lean causes backfires. Tune where you get the best transition *just* rich enough where it doesn't wheeze or backfire as you advance the throttle.
    The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
    "It's a new day for Auburn" - Gus Malzahn
  12. #12
    Join Date
    Feb 2011
    Burlington, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hobbsy
    Ibow to your supreme knowledge.
    Idid exactly as you said and the engine ran great. No rpm drop off at full throttle.
    Iam starting to figure out that for each low speed setting, there is high speed setting that works the best for the low speed setting.
    If your low speed setting is not correct, you can still adjust the high speed setting to get a seemingly optimum setting evan if the low speed setting is off.
    You have to go back and forth to get the right combination.
    Thank you again for the info. I hope to be knowlegable enough to help people on these forums.
    Thanks again.
  13. #13
    Join Date
    Feb 2011
    Burlington, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the info btw. I am starting to figure this out.
  14. #14
    Join Date
    Mar 2004
    Opelika, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    An incorrect low speed will screw up attempts to set the high speed. Hobbsy always advises to peak the high speed, leave it there, and set the low speed correctly. Go back and set the high speed a few hundred rich. This really is the best method to tune a 4 stroke,
  15. #15
    1QwkSport2.5r's Avatar
    Join Date
    Oct 2006
    Cottage Grove, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: blw
    I follow his tuning method on my Enya 4-stroke as well. I use a tach as I don't quite have the 'ear' for setting the needle on a 4-stroke just yet.. Still new at the 4C scene.
    GlowHead Brotherhood #3
    Real engines use glow plugs.
    R.i.P Jacob Wetterling #11 10/22/1989
  16. #16
    Hobbsy's Avatar
    Join Date
    Dec 2001
    Colonial Beach, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    1Q, my very first RC engine was an Enya .46 MKII which I still have. I know that many on here advise to not get a fourstroke first. The only mistake I made, (according to some), was using Fox fuel with 20% castor for its first two seasons. This did not have the devastating effect that some think. It only got a brown muffler. I used the same fuel in a Saito .80 and 1.50, no ill came to them either.
    CR==15.3 to 1
    Max pull== 14,178
    Front tires==11x15
    Rear tires 24.5x32
    Weight==12,550
  17. #17
    Join Date
    Mar 2004
    Opelika, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I like gadgets and have a newer TNC tach. I use it most of the time out of curiosity for the numbers. You can tell more by listening though.
  18. #18
    Join Date
    Oct 2006
    Cottage Grove, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Hobbsy
    I've been in RC for over 15 years, but most of that is with cars only. I wanted to have a 4C just to have one and it so happened I fount the Enya. The instructions say to use castor oil or a high quality synthetic, and being of the "old school" belief, I use all castor in my aero engines. I save the synthetic oil for the car engines that rev to 40k, the thick castor hold the rpm back some.
    With my Enya 60-4C, I find if I start rich and lean it until it runs smooth, it's still 1000rpm rich of peak. By smooth I mean clean four stroke, no missing or popping. The 600-700rpm I gain using the tach doesn't sound much different to me. Again, this is my first season with a 4-cycle, and being an old Enya, it's got it's own learning curve. I still find it comical seeing castor "goo" spraying from the exhaust at fast rpm. I don't know why.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
