If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 8 of 8
  1. #1
    Join Date
    Jun 2006
    Middlefield, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Can't remove cylinder liner!!! O.S. .32
    I just bought a used Kyosho Caliber 30, and tore it down to check on everything before I fly it. It has an O.S. .32 heli engine in it, which was locked up. After spraying some PB Blaster in it, it loosened up and turns nice and smooth now, but I still want to disassemble it to check the bearings, ect. My problem is, I can absolutely not get the cylinder liner to come loose. I've tried the old zip tie in the exhaust trick, didn't work, tried stuffing a bunch of toothpicks in it while cranking it (cuz the zip ties just sheared), didn't work either. Tried a heating and cooling cycle to loosen it up, didn't work. Now what do I try????
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1838638   Click image for larger version.
    Lifetime member of PETA, People for the Eating Of Tasty Animals
  2. #2
    Join Date
    Sep 2012
    Ormond Beach, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Can't remove cylinder liner!!! O.S. .32
    Put a nut on the crankshaft.  Heat engine in oven at 250 for about 20 minutes.  While still hot, use leather gloves to hold it, turn crank till piston is just below top of exhaust port, place a copper washer from a glow plug on top of piston and hang out exhaust port just thickness of cylinder sleave, turn nut on crank with wrench to push sleave up with piston top and copper washer.
    I have never had this fail.
    Good luck.
  3. #3
    Join Date
    Sep 2012
    Ormond Beach, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I just noticed it is not a threaded crank so you will have to use the same method with a different way to turn crank like a allen key through hole or something else.
  4. #4
    Join Date
    Jun 2006
    Middlefield, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks. While I was offline, I decided to try heating it again, used a torch to heat the case, and then I was able to get it loose. My new problem is unscrewing the clutch bell (or whatever it's called) from the crankshaft. I'm sure it's put on with thread locker. Got any tip's for that?
  5. #5
    Join Date
    Sep 2012
    Ormond Beach, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Heat agai, with the rod still attached to the piston you can put a piece of wood under the crank in the rear of the casing to stop the shaft from turning.
  6. #6
    Join Date
    Jan 2002
    Minersville, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Put the prop nut on and don't screw it past the threads. Then take a wood block and put that on top of the nut and tap the block with a hammer it should pop off easily. Note! I said tap it off it is not a 10 penny nail.
  7. #7
    controlliner's Avatar
    Join Date
    Mar 2009
    Ontario
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Using the foreign object in the exhaust port will only work if it is an ABN engine. If you try this on an engine with a ring chances are you will pinch the ring in the groove with this kind of pressure and damage the piston
    \"Keep it clean and not too lean\" Duke Fox
  8. #8
    Join Date
    Jun 2006
    Middlefield, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hmm, this is a ringed engine. Hope I didn't damage it...
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
