If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 79
  1. #26
    Join Date
    Jun 2003
    winter park, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    OK GROUP Maybe repeating myself have 50 plus engine most are diesel or diesel conversions and 8 or 9 4 strk glow I have never lost a bearing in any engine,or rust the 4 strokes
    get a short run on model diesel fuel (plug energized) they might sit for a year or more gummy sometimes a quick rinse with diesel fuel solves the issue
    on one of my OS instruction sheets it states rinse well with KEROSENE and then store in plastic bag if storing fror a period of time
    PE Reivers suggestion of" how to" is a good one also- martin
    If you check the diesel site you never see this come up, failures sure, broken cranks, egged out rods, thats about it
  2. #27
    Join Date
    Jul 2010
    Palatine, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    Ware as the engine made? Some of the newer OS engines are being made in China. Low quality china bearings could be the source of the rust.
    Listen!!! Do you smell something?
  3. #28
    JollyPopper's Avatar
    Join Date
    Oct 2002
    Mountain Home, AR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    To get back to the OP's question, it smells like smoke to me. For bearings with that little time on them to fail, he would almost have to be putting something corrosive in the engine between runs to achieve it. BS
    \"In theory, there is no difference between theory and practice; In practice, there is\"
    Intolerance is not to be tolerated
  4. #29
    Join Date
    Jan 2004
    fairfield, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    ORIGINAL: Lightspeed1551
    +1
    AMA # 126183
    YS Engines
    Team JR AMERICAS
  5. #30
    Join Date
    Apr 2005
    Sandy Hook, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    I have an OS 120 AX that eats bearing every 50 flights or so. I thought it was something I was doing until I found out a whole lot of other people were having the same problem. I replace bearings in that engine twice. Then the third time I switched to Boca bearings, I got the high performance speed bearings so far so good. It is very possible it was rust, but I have never heard of that before but it is possible. Maybe moisture got in there some how from your fuel or whatever I am not sure though. You said you live in a very dry climate I am not sure how else moisture could get in there to cause the oxidizing of the metal except from maybe a bad batch of fuel.
    \"This is a model airplane...But like Burger King, FLY IT YOUR WAY!\"
  6. #31
    Lifer's Avatar
    Join Date
    Aug 2008
    Kansas City, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    Several years ago I was using a fuel that had extreme pressure additives, which was explained to me were chlorine based. Good for wear protection but promoted rust if not cleaned off after running. A friend heard of the problem and gave me a can of "Corrosion X." No rust issues since, in over 15 years. Hope this helps.
    AMA #77967/CD/LM
  7. #32
    Join Date
    Dec 2006
    ToowoombaQLD, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    I'm not going to pass any judgment on what Jaka's doing with his fuel and engines and I thank him for the pictures. However I've never seen a rear bearing AND crankshaft look so rusty in anything I've ever run.
    Here's a couple of photo's of the three bearings I've pulled from my YS DZ170 pattern motor at the end of each season. The one one the left has a few rust spots but it's mainly oil staining and it has been sitting in a bag (straight as removed from the engine) for at least 2 years.
    Fuel is home brew 10% coolpower blue oil, 20% nitro (cheapest stuff) and 70% methanol (industrial stuff nothing fancy). Motor gets irregular running and can be a few weeks between flights, then 4-5 flights/day when I have the time to practice. Never run the fuel out and never put after run oil in it and lugging an 18.5x12 prop. Everything in the cooler parts of the engine has like a thin green/blue film over it that wipes off with a finger.. I believe Koyo are a good bearing though, and OEM for my engine...
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1845966   Click image for larger version.
  8. #33
    Hobbsy's Avatar
    Join Date
    Dec 2001
    Colonial Beach, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    Corrosion X is the best after run oil of all, bar none. Not only is rust prevented but keeps engines as clean as new inside.
    Minneapolis Moline G 1350, 585 cubic inches, 141.4 hp, 9.7 GPH fuel use, 4.75 inch bore, 5.50 inch stroke
    CR==15.3 to 1
    Max pull== 14,178
    Front tires==11x15
    Rear tires 24.5x32
    Weight==12,550
    Club Saito member #5
  9. #34
    controlliner's Avatar
    Join Date
    Mar 2009
    Ontario
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    I don't use after run oil, ever. I have plane and car engines, none of them have rusted bearings. I believe using ARO strips the surface of any rust preventative ingredients and causes rust. I use Omega 10%. I also believe that the higher nitromethane fuels (which I don't use) have a higher incidence of rusting.
    \"Keep it clean and not too lean\" Duke Fox
  10. #35
    Join Date
    Aug 2004
    Paola, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    ORIGINAL: Hobbsy
    Hobbsy - do you buy it in the 16oz bottle with the sprayer top, or is the smaller bottle packaged for firearms the same stuff?
    Or, do you buy the spray cans? Just wondering..
    Out of all the places we could be, this is one of them.
  11. #36
    ovationdave's Avatar
    Join Date
    Apr 2005
    Linden, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    The description for corrosion X is the same for three products: Corrosion X, Corrosion X Aviation, and Corrosion X for Guns. I don't know what the difference is, but I have used Corrosin X (red aerosol can) for years for Long Term engine storage. I don't use it as a regular after-run oil, however I am sure it would work well for that if you used it that way. I do know that my aerosol can eventually lost its pressure and I had to empty the can into a bottle to continue using it. I would prefer to by it in a bottle but the only one that I see like that is corrosion x for Guns.
    Dave
    I have not failed. I\'\'\'\'ve just found 10,000 ways that don\'\'\'\'t work - Thomas A. Edison
    Sig Kadet Brotherhood member #18
  12. #37
    Join Date
    Jan 2012
    Marydel, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    Sport_Pilot ...You should educate yourself before making a statement like the following:
    "We are talking about a two stroke, there are no combustion products in contact with the crankshaft of a two stroke."
    Please go take a basic mechanics course at your local community college or the local high school before making any more statements about any engine or how it operates.
    Why do you think that there is oil in the fuel we use in the glow engine? It's there to lubricate the entire engine, including the crankshaft, and bearings, and cylinder and piston(s).
    AMA 544562 - Tiger Club #35
    Owner/Operator ... http://www.aeromodeler.com
  13. #38
    Join Date
    Jan 2004
    fairfield, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    I never use after run oil and never will!
    look up the OS 140 engine and what all the Pro's did soon. On every new engine the would remove the stock bearings and replace them.
    AMA # 126183
    YS Engines
    Team JR AMERICAS
  14. #39
    Texastbird's Avatar
    Join Date
    Jul 2002
    La Porte, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    I had a 61FX peel the liner real bad after only a few flights. I sent it in under warranty and they told me the bearing had rusted causing the destruction of the liner. Total rubbish of course, but they did replace the engine. The best way to prevent corrosion in a glow motor is to follow Pe's recipe and run the engine on it long enough to get the contaminates out of the lower parts of the engine. It only takes a few minutes at the end of the day. I use lighter fluid because its easy to find and a mixture of transmission fluid and Marvel mystery oil. Just pouring some oil in the engine does nothing to flush the nitro out of the engine. But burning it out and replacing it with the naptha and oil mixture really does the trick.
  15. #40
    Join Date
    Mar 2009
    Ontario
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    ORIGINAL: camsbad
    Sport_Pilot ...*You should educate yourself before making a statement like the following:
    ''We are talking about a two stroke, there are no combustion products in contact with the crankshaft of a two stroke.''
    He knows that there is always a fresh charge of fuel entering the crank case. What he is stating is that there is no spent fuel residue entering the crank case like in a model four cycle engine.
  16. #41
    fly24-7's Avatar
    Join Date
    Dec 2005
    Shrewsbury, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    I'm no engine expert, but it's hard to believe that rust would build up that quickly to the point of killing the engine. I have multiple engines that are 5+ years old. I run Omega fuel and burn off as much of the residual fuel in the engine as I can at the end of each flying day. I do nothing special in the winter when the planes sit in the basement. Just leave them dry. I've never had a problem getting an engine running again in the spring.
    I have to say I have no idea what these engines look like on the inside because the only thing I've done maintenance-wise is replace spent glow plugs. They run strong and start very reliably. So, it sounds to me like the hobby services guys are reading you a line out of some troubleshooting manual. It doesn't make sense to me that an engine would go bad that soon unless there's a defect in it or it was badly abused.
    Why yes, I use mixing. Balsa, light ply and on occasion, dirt...
  17. #42
    MJD's Avatar
    Join Date
    May 2003
    Orangeville, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    ORIGINAL: camsbad
    No way... really?
    We're all happy that you took basic mechanics, obviously you excelled at the subject. Perhaps you could take a minute to explain the operation of a 2 stroke front intake glow engine for the rest of us who don't get it? I always thought combustion took place in the combustion chamber, and the combustion products went out through the exhaust port - but evidently I have it all backwards like Sport_Pilot.
    Maybe next time proof read your post before sending. Or take reading comprehension at the local community college.
    Marine GOOP = magic faerie boogers in a tube, sticks everything.
    Revver Bro #231
  18. #43
    Join Date
    Mar 2009
    Ontario
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    Eating Popcorn
  19. #44
    Sport_Pilot's Avatar
    Join Date
    Jan 2002
    Acworth, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    ORIGINAL: camsbad
    You are the one who needs a mechanics course, or maybe english course, not sure which. The burned nitro and burned methanol (combustion products) go out the exhaust, thus the nitric acid never touch's the internals of a two stroke.
    Glow Head Brotherhood #15
  20. #45
    earlwb's Avatar
    Join Date
    Aug 2009
    Grapevine, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    I have remembered that a few people had mentioned that they may have chosen the wrong bearing size as well as specified the wrong type of  bearings to use as well.  Probably some accountant types got in the way using it as a cost cutting measure.  Not all ball bearings are the same. They may look the same visually, but there are quite a few subtle differences in their designs and how they work too.
    Club Saito #722, Sig Kadet Brotherhood #80, GlowHead Brotherhood #14,
    AMA # 928076
  21. #46
    Join Date
    Apr 2005
    Linden, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    ORIGINAL: controlliner
    Eating Popcorn
    Pass the butter please!
  22. #47
    Join Date
    Jun 2012
    Poway, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    PE Reivers wrote "the end user is to blame, mainly because he did not get the proper instructions to keep his engine free of corrosion after he shut it down at the field.
    EVERYbody knows about the use of "after run"treatment
    ", unless you are a novice at running glow engines. (here lies the problem)"
    Perhaps he didn't read my original post. 2 or so month's I've been flying this plane a couple of time/week over the 2 months I've had it. (so it doesn't sit around) I do run the engine dry at the end of each day. Drain the fuel and run the engine til it quits. Then with the glow plug driver attached turn it over with an electric started several more times. Then put (as per instructions on afterrun oil) several drops ARO into carb and through glow plug hole. Then turn over engine again with electric starter. It seems to me that perhaps "EVERYbody" doesn't know about the use of afterrun treatment.. Several of the posters state they never run after run oil. And if you speak with the folks at Morgan Fuels, they say you don't need to use ARO with their fuels. So what I surmise from the posts so far: Possible a bad bearing/cheper bearing materialfrom the start, remove back cover to check for rust before sending to Hobby Services, ARO certainly won't hurt, run engine dry at end of day.
  23. #48
    aspeed's Avatar
    Join Date
    Jul 2011
    Ruthven, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    I am going out on a limb here and saying OS should stand behind their choice in lousy bearings.  I never used after run oil in any motors for 40 years unless using nitro over 10% nitro, with no problems with rusty bearings.  I have had a bit of rust on crankshafts that came off with steel wool/fine sandpaper, and have only replaced bearings on swap meet and garage sale motors.  There is always the choice of plain bearing motors too.
    Glow Head Hood # 7
  24. #49
    Join Date
    Apr 2005
    Linden, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    I have to say, I know some have been razzing this issue a bit, but in all honesty, at the end of a flying day, for YEARS, all I did was empty my tank, wipe off my planes, and load up. I have NEVER had an issue with my engines. No ARO ever.
    Its a faulty product. Plain an simple.
    ~Dave
  25. #50
    Moderator blw's Avatar
    Join Date
    Mar 2004
    Opelika, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS 65AX ABL
    ORIGINAL: camsbad
    You didn't mention bushed connecting rod ends.
    The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
    "It's a new day for Auburn" - Gus Malzahn
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
