inverted 4 stroke Saito 72.....help
RE: inverted 4 stroke Saito 72.....help
ORIGINAL: 1QwkSport2.5r
Not all of us are as passionate about CDI ignition as you are. I think the vast majority of us run glow ignition, so assuming the OP is using glow ignition, my comment was pertinent.
ORIGINAL: SrTelemaster150
Wet glow plugs?
What are those?
I've really only ever gotten wet glow plugs out of the deal, never a hydro-lock. Or hydraulic lock for the persnickety.
What are those?
Really?
Really?
Well obviously you have more to say than I do that's far more relevant than anything I have to say. So by all means, the floor is yours.
Really?
Really?
If I ran small displacement engines glow would be an option.
As it is, my FA91S is borderline as it is a shoehorn fit to get the module into the small airframe..
I tried running it on glow ignition, but after getting used to CDI, GI is a PITA so I found a way to get the module into the fuse.
Man, lighten up, I was just kidding.
If I ran small displacement engines glowm would be an option.
As it is, nmy FA91S is borderline as it is a shoehorn fit to get the module into the small airframe..
Really?
Really?
I'm a glow guy, and prefer it over CDI or magneto ignition even if ignition makes a little more power and saves a little fuel. To me, it's simple. Anyway, inverted Saito .72 is the subject... I'm done with my hijack. Sorry.
What hijack??if you girls don't kiss and make up my mate loose bruce is going to fly over and settle it with his favourite springfield p9 re-chambered to 357 so he can put some 38+p's thru it.Guy loves them
