Webra 50 carb replacement parts?
i am an idiot, I somehow lost my needle valve to my Webra 50, I took it out last fall and I can't seem to find the needle valve. Does anyone have a recommendation for a replacement needle valve or carb?
I see a lot of Webra parts on eBay from time to time. I'm not wise enough to know if a NV from an old ST or other old design engine will work or not. Some of those old engines use the same size and thread pitch on the NV.
Thanks guys, I have been keeping an eye on Ebay, I currently stole one from my Webra 55, so I can test the plane. I have tried to do some searching, but I can't seem to find on paper a replacement. I am going to keep trying and maybe I will find the safe spot where I placed it
Jon
Jon
TX
HSN needle valves are pretty common. They are either blunt tip and sharp tip configuration. I would try one off any other engine close to an engine the same size . If the threads work, go for it. After all they are all pretty much the same. Otherwise hunt around eBay. Or try Bob Boumstein, he sells used engines, carbs and mufflers. His email address is http://bobsengines.com/
Thanks guys, I think one of those would work, but I don't think I could take/buy one from you, you may need it.
I was just able to get a little time and I emailed Bob, to see if he has anything.
Jon
Jon
Gents,
Continuing this thread on a similar quest, would anyone have a spare carb to suit a Webra Blackhead (10ccm/61) ?
Original TN type preferred but TN2, Dynamix also fine.
I thank you in advance,
DF
DF
Last edited by DerFly; 09-05-2013 at 01:43 AM. Reason: Engine Capacity - 10ccm/0.61
