ANYBODY know how to bring a LiFe 3.3v cell down to 1.5v~1.6v for onboard glow heat?
Reply
Old 12-01-2013, 08:27 PM
psgugrad
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default ANYBODY know how to bring a LiFe 3.3v cell down to 1.5v~1.6v for onboard glow heat?
I posted this question a week ago in the battery forum and no one answered...surely I can't be the only guy who wants to do this. Would I use a diode? a regulator? resistor? Any advice appreciated.
PS: I experimented by simply placing a 2nd glow plug in the line and a 1000mah 3.3v cell ran them for 15 minutes...REALLY hot...engine ran like a sewing machine. If I had something to cut the output voltage in half, would the cell run 1 plug for 30 mintues?
psgugrad is offline
Old 12-02-2013, 03:34 AM
tipstall 131
tipstall 131's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can use a regulator curcuit. I intend to that for on board glow as well. I bought a DIY regulator kit from an electronics store here. You should be able to get the same thing from radio shack where you are. It is realy simple to build. A few components to solder and you,re ready.
tipstall 131 is offline
Old 12-02-2013, 04:32 PM
bjr_93tz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A linear regulator type will act as a variable resistor to keep the output at 1.5V (or whatever it's set to) and disipate the rest of the volts x current as watts (heat) for no real efficiancy gain.
A switching type regulator will turn the full voltage on and off really quickly with the ratio of on-off determining the average voltage. For something as dumb as a glow plug a 555 timer circuit set to switch at a coupled of hundred hertz with a duty cycle about 40% would do just fine..
bjr_93tz is offline
Old 12-03-2013, 03:53 AM
tipstall 131
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
BJR, could you please elaborate on this curcuit? Do you perhaps have a schematic drawing? I went to the elctronics store and they gave me a linear regulator kit but made no mention of the swicthing mode regulator. This sounds like a better solution.
Old 12-04-2013, 10:00 AM
jaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi!
Why do you want on-board glow?? It's not needed on any two or four-stroke glow engine if you set the carb right, mount the tank according to the tank mounting rule and use the correct fuel andf glow plug.!
jaka is offline
Old 12-04-2013, 06:07 PM
flyingagin
flyingagin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How about this On-Board Glow Igniter 1.5V 3A
http://www.hobbyking.com/hobbyking/s..._1_5V_3A_.html
Specs:
Input: 6v~23v
Output: 1.5v 3A
Dimensions: 22.9x20.3x7.6
Weight: 8g
Ken
flyingagin is offline
Old 12-05-2013, 10:22 AM
earlwb
earlwb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would just simply use a on board glow ignitor and two LiFe cells in series. I have a couple of planes using that setup already.
earlwb is offline
Old 12-05-2013, 12:04 PM
psgugrad
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok but how do you get the voltage down?
psgugrad is offline
Old 12-05-2013, 06:20 PM
JPMacG
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You could rip the innards out of a power panel.
JPMacG is offline
Old 12-06-2013, 06:00 AM
psgugrad
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That crossed my mind!
psgugrad is offline
Old 12-06-2013, 11:55 AM
earlwb
earlwb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well the onboard glow ignitor has its own electronics built in that reduces the voltage down to a safe level for the glow plug. They usually include a circuit for measuring the current flow and adjust it as well, plus they include a circuit that allows you to set the turn on based on the throttle position too.
You can also perform a GOOGLE search for "glow plug igniter schematic" and see if any of those methods that show up will work for you too. Unfortunately some are from another forum though.
earlwb is offline
Reply
Display Modes
