Super Tigre G-51 question
Hi all,
I made a stupid mistake reassembling the carb of a ST G-51, and ended up loosing the little O-ring on the HSN. For now, I just used a piece of fuel tubing over the brass knurled piece to minimize air leaks, but I would
rather have the thing fixed properly.
I would just buy the whole HSN replacement, but everybody seems to be out of stock. So I was wondering if anybody can tell me the dimensions of the o-ring, and I can order it from mcmaster-carr...
Alberto
Alberto
Hi all,
Alberto
Alberto
edit: any seal on the main needle is only going to seal the fuel from leaking out, not air leaking in.
Look at the description here
http://www.advantagehobby.com/79541/...%3DSUP12163145
under the include tab. There is a spring behind the O-ring that pushes it towards the spraybar, where there is a small recess to house it. Instead of installing first the spring, then the O-ring, I did the opposite. So now the O-ring is jammed inside the brass piece, where it does nothing.
I flew it yesterday, and the fuel tubing seems to work. However, it makes it more difficult to turn it (and tune it)...
Two of my ST's have that exact needle and neither has an O-ring. If it were me, I'd pick the old O-ring out and forget about it. Unless it spews a ton of fuel out of the needle, I wouldn't mess with it. If it does leak, leave the fuel tubing on it. IMHO its not worth the time and money to find an O-ring. Just my opinion though.
