Hp 61 nitro engine silver star
HI all im a new member and can anyone help me i rexently bought a pica waco and it has a HP 61 silver star nitro engine installed but i cannot get it to max rpm does anyone know how to tune these as a cannot fint the low end needle it is not on thr throttle arm but there looks tow be two settings on the other side of the car one is the high eng needle as i can unscrew it out fully but the larger wheel is fixed onto the carb can any one help please
Some of the Siliver Stars had a Perry carb. The wheel you mentioned is the idle mixture. If it has been sitting a while you need to replace the Oring and it may be stuck. Soak the carb in some fuel overnight and that should free it up. I cannot remember how to take it apart as it has been a while, but I am sure it would come to me if it was in front of me.
My Feedback: (20)
You can get some information/parts for this engine from MECOA I just bought a new muffler for one of the HP Gold Cup engines.
http://www.mecoa.com/hp/index.htm
https://mecoa.biz/shopdisplayproducts.asp?id=122
hi thanks for your reply but i donth think it is stuck as they both turn the larger dial just keep on turning but the smaller one i can unscrew out from the larger one fully and is a needle valve so does the larger dial have to be in a specific locatiopn ?? i live in the UK but cannot find any info on how to set up the low end or high end settings...
There should be a mark or indent on the knurled wheel. There are two marks on the plastic body one says R the other L and a center mark between. The mark on the wheel should be somewhere between R and L with R for rich and L for lean. Start with the wheel at the center mark and tune it as you would most except you turn the wheel to R or L as required, and it should be very small movements, just barely turn the wheel for each adjustment. I had to change in for summer and winter and after a while I would know exactly where it should be for the season.
hi i have looked but there is no plastic body the whole carb is aluminium the large wheel has a notch out of it but the needle that screws into the larger wheel has nothing at all on it ? also there are on letters on any part of the carb
You must have the older HP rotomix carb, I thought that only the older Gold Cup series had that carb. It works like the Perry carb but is not the same. I suspect the notch goes at the top and then works similar to the Perry but beyond that I cannot help you.
