Muffler Question re OS 120 AX
1 Post
Hi All,
Has anyone used a inverted pitts style muffler on this motor?
Several years ago , I tried and ran into problems with backpressure ( lack of it ) using one of these mufflers. Could never tune the engine properly.
Are there people using them without problems ? What particular brand ?
Cheers
Merlin Man.
Cheers
Merlin Man.
1 Post
Hi,
Maybe the inverted muffler is not called a pitts style. ? The slimline Q I just looked up is for a side mounted engine not an inverted engine?. I need the latter. Anyway, thanks for your reply.
Cheers,
Merlin Man.
Cheers,
Merlin Man.
Check your tank location w.r.t the carb. OS 2c engines are very susceptible to being untunable when carb is below the tank centreline when inverted. Had a similar issue with a 75 ax some time back
Ameyam
Ameyam
