1/4-32 spark plug connector to Rc Excel Electronic ignition.
I have an urge to try a glow engine on spark ignition using E85 fuel. I was reading up on another thread that it works reasonably well even with a methanol carburetor (so I don't need to use a walbro carb) but I'd need to use a spark plug for ignition. I have an old Rc Excel ignition unit that I can use for the experiment but it connects to a larger spark plug. What would it take to convert it to use the smaller kind?
Thanks in advance for your replies.
FL
Go to- http://www.agaperacingandhobby.com/v...?productid=428 - to find the part you need. I have done them on a Tartan twin, with no problem. red
My Feedback: (102)
Also, you'll find what you need here. The 120 degree one works perfectly on engines where the plugs are down between tall cooling fins, like on a Saito 1.50 for example.
http://www.ch-ignitions.com/index.ph...oller=category
