OS 1.08 FSR recommendation
Hi all,
what prop size do you recommend for this nice engine? It is planned to be run with a tuned pipe in a 65" wingspan MXS-R, about 10lbs flying weight.
Also your tips for tuned pipe length are welcome.
thanks
Dominik
thanks
Dominik
My Feedback: (404)
I would start out with a 15x6 prop and go from there. The 1.08 is a very good dependable engine, high torque, keep tune pipe long and work your way down using a tach. See full info at http://www.macspro.com/tuning.asp
My Feedback: (29)
I have has a couple of these engines. One of OS's best efforts as far as I am concerned. The first was on a Lanier 1/4 scale Laser and the second was on a CG Extra. both very similar to your airplane. The best size was a 15X8. Keep the pipe somewhat long as you don't want a narrow powerband. The 1.08 is a torque monster so so too short will be counterproductive. Both of mine were run on Slimline pitts mufflers.
Thanks guys.
I have run my used 1.08 FSR now on for the first time after it got a new sleeve and piston on the bench. So far I am very pleased how it handels. Tuned pipe installed with uncut header, which results in about about 23,5" distance from exhaust to baffle.
I took it of course easy, really rich setting, 22% castor oil, 12x8 3-blade for low load. It looks to become a favourite one!
NY
I bought an OS 1.08 in '94...it's now powering it's fourth warbird. GREAT engine! I run it slightly rich with a 16x8 APC. Currently in a 14 lb Top Flight Sea Fury. Still pulls great!
My Feedback: (43)
My Feedback: (29)
I have a soft spot for Lanier airplanes. My last one was a 33% Laser, I has able to lighten it up to 15 lbs and powered it with a DA 50. My 1.08 powered 1/4 scale Laser was just shy of 8 lbs. It was almost like flying a big foamie. I also had a Giles 202. Powered with a 3W 70 twin and came in at 21 lbs.
Lots of nice info, thanks to all. it seems I got a OS jewel in my hobby barn....
The MXS-R plane is coming closer to be finished, but progress is somewhat slow. I Installed a tuned pipe half tunnel to the underside of the fuselage, the covering foil still has to be closed again and provisions needed to attach the pipe to. More or less done so far, engine installation is next.
Hope to be able run the 1.08 on the test bench this weekend with the 15x8 and the pipe, and do the stepwise shortening of the header. I will post some rpm numbers once done.
By the way, the carb of mine doe not have the sleeve insert.
My Feedback: (132)
PA
In fact, I still have the engine and would love to find another Lanier 25% Laser kit. I now know how to build it MUCH MUCH lighter.[/QUOTE]
JeffH, I have a 1/4 scale Laser kit by Lanier I'd let go, make me an offer.
Mark
P.S. I think only the OS 140 would be my vote to beat the 1.08. (But not by much.)
Mark
Finally some figures, still from test bench:
9.700rpm @ 22" pipe length, 8% nitro, 15x8 Master Airscrew.
Engine is now installed to airplane, and I am going to cut one more inch off the pipe. Hope to get into the 10K range then.
That will be plenty for this little airplane, I am sure it will be less 10lbs flying weigth.
Thanks all for your input.
Dominik
Dominik
Yes I heard it more than once to better call those MA props a paint stirrer...
And in fact most of the time I am using APC or Graupner G-Sonic props. That 15x8 MA was just at hand.... need to buy an APC.
Use your Prather Pitch Gauge and notice the Master Airscrew is one inch less than advertised anyway.
Almost all props are short about an inch of pitch than advertised, except APC. They are a quality unit, especially for the money.
My dad has a 1.08 in his 17 lbs Four Star 120, that thing is amazing. Best engine ever. I'm finishing a Lanier Laser 1/4 scale and have a 1.08 in it. Can't wait.
Chris...
Chris...
