OS 61 FSR with MA 11x7.5
After freshening up my old 61fsr and running a couple tanks thru it I measured the RPM and got 11,350ish out of it. I don't recall what it used to run and I don't think I have had a 11x7.5 prop before. Does that sound about right?
thanks!
thanks!
Haven't tried mine, but these may help:
http://www.rcuniverse.com/forum/tach...os-60-fsr.html
http://www.rcuniverse.com/forum/tach...1-fsr-abc.html
You could get this engine ringed or ABC, I have both. Unfortunately all of them are about worn out. I was able to get an ABC piston/sleeve from Shadel some time back and get superb performance from it. I wish I could find a couple more of them, best $90 I ever spent repairing an engine. As much as I like the FX series there's just something about the FSR's that appeal to me.
Rick H.
Rick H.
I bought another used 61FSR detail out and refurbish as a project. It's in pretty good shape but I need to find a puller for the prop hub so I can replace the front bearing. I've seen a OS one that looks pretty simple to use.
Tbob. I've been using a cheap battery terminal puller. The type to pull leads off a "post" type automobile battery. I got mine from an auto parts store over 30 years ago. I had to do a little modification to it, but it wasn't anything that had to be precise. Good luck, Greg
