Help! Saito 91 siezed at break in!
Old 05-10-2015, 04:54 AM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Edited for content.
Last edited by 1QwkSport2.5r; 05-17-2015 at 09:21 AM. Reason: Making sure the edit button still works.
Old 05-10-2015, 12:58 PM
the pope
Glad you said some there Tim ! I hold myself to somewhat higher standards then riffraff like O.F. F.W.I.W. I have the throttle fully open and control the revs with the H.S. mixture thingy ( I think its called ) to begin with . The amount of fuel they guzzle at this stage is a real eye opener but it gives me the warm and fuzzies . I start to lean it out and warm it up from there . %20 oil at least for run in and then %20 oil there after and %10 nitro is all she gets . I always prelube them and pull the backplate to check for swarf and lube at the same time and saitos are the ducks guts as well as most other manufactures . Cheers the pope
Old 05-11-2015, 04:50 AM
Rudolph Hart
Rudolph Hart's Avatar
That's it i've stuffed a rag in my mouth and it's big! tricky?
Tim i'll run the flag up too,it was all in fun mate.
Old 05-11-2015, 04:55 AM
Rudolph Hart
Last edited by Rudolph Hart; 05-11-2015 at 04:59 AM. Reason: It's a double post,must be getting serious :)
Old 05-11-2015, 05:02 AM
Sport_Pilot
Sport_Pilot's Avatar
Originally Posted by EBGFLIGHT
Not Hydro locked but I don't see how it would be too lean since I set the needle to the manufacturer specs.
Manufactures specs are often way off, especially if there is any dust in the needle. I always set them much richer than the recommend settings. Yes it may be hard to start, but no damage from being too lean.
Old 05-11-2015, 06:34 AM
  #31
1QwkSport2.5r
I'm gonna stay out of anything Saito from now on. I'd hate to be giving poor advice (or opinion in poor taste). You guys are the experts.
p.s. I had nothing to do with the removed posts.
Old 05-11-2015, 08:32 AM
  #32
EBGFLIGHT
EBGFLIGHT's Avatar
Anyway I took the engine apart and it is the con rod seized to the crank pin. We'll see what HH has to say about the Saito warranty on this
Old 05-11-2015, 08:33 AM
  #33
EBGFLIGHT
EBGFLIGHT's Avatar
Must not have gotten enough blow by to be lubed properly. next time I'm just going to lube it before I run
Old 05-11-2015, 09:27 AM
  #34
the pope
Hi there Tim YOUR BIASED !!! A few of my posts are gone as well . At least Im not alone this time .You must not upset the saitofiles . Now go to the naughty corner . Cheers
Old 05-11-2015, 09:52 AM
  #35
ForcesR
EBGFLIGHT; the same happened to my Saito during breakin, but I didn't take it apart, I sent it directly back to HH for warranty repair. They covered the repair and sent me back the engine with a note stating that there was flaw with an oil groove in the connecting rod. From what I read later, Saito had a batch of flawed connecting rods that got installed in engines that were later returned by customers who had their engines seize during breakin.
Roger
Old 05-11-2015, 10:17 AM
  #36
1QwkSport2.5r
I hope the OP gets his engine fixed and running soon.
Old 05-11-2015, 10:39 AM
  #37
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
It may have been missing this slot in the bottom.
Old 05-13-2015, 09:48 PM
  #38
JollyPopper
JollyPopper's Avatar
"Edited due to bias"? What the hell does that mean? Edited by whom? I thought censorship was frowned upon here in the good ole US of A.
Old 05-14-2015, 03:23 AM
  #39
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
JP, it was edited by the poster himself, not by Moderators. Hopefully it will pass and we'll all be friends again.
Old 05-14-2015, 05:06 AM
  #40
Rudolph Hart
Not likely dave...you mean tim lied to us and edited his own post then blamed you guys to drum up some sympathy for himself?? golly gosh i'm real mad at him now even if he turns out to be a saito closet lover,and trust me,there's nothin lower in my book
Old 05-14-2015, 05:32 AM
  #41
1QwkSport2.5r
Some of you guys are something else.
I was talking smack about Saito that spurred a few attack posts that were subsequently removed and I didn't want any further BS to ensue. Being I'm biased against Saito engines, I retracted most of what I'd said so the proper authorities could properly advise the OP as to what to make of his .91 that didn't survive break-in.
Sorry i I mudded up this thread. I'll be sure not to let it happen again. Have a great day!
Old 05-14-2015, 05:35 AM
  #42
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Tim is more of an Enya guy which is all good, I'm the real problem child here, I just ordered an OS .56 with my wife's blessing. Our youngest daughter gave me $300.00 towards it. I'll have to write about it in another more appropriate thread. You be careful and don't drink too much lube. The Saito .56b is about 60 bucks cheaper but I have a .50 and a .62. If I can con another daughter maybe I can get an Enya .53
Old 05-14-2015, 05:47 AM
  #43
the pope
Its alright Tim I'll still talk to ya . After all us boaties have to stick together . Should check out Tims runs with his boats , pretty impressive and no piddly 4 stroke saitos on his machines . Jetts all the way ! Cheers
Old 05-14-2015, 05:50 AM
  #44
dmrcflyr2
My Feedback: (43)
The Enya 53 is quite difficult to come by now. It took me two years searching for a NIB unit and I finally found it.
Old 05-14-2015, 05:52 AM
  #45
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Congrats, it's a fine engine
I'll have to apologize to EB for running off course here.
Old 05-14-2015, 06:01 AM
  #46
Propworn
Propworn's Avatar
EEEEEEEEENNNNNNNYYYYYAAAAAA!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!! Just funnin!!!!
Old 05-14-2015, 06:17 AM
  #47
Rudolph Hart
Who's eb?
Old 05-14-2015, 06:31 AM
  #48
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
The OP of this thread.
Old 05-14-2015, 07:15 AM
  #49
1QwkSport2.5r
Wait.. Someone is bound to give me flak for that now too... "You put a Jett on a boat?? "On more than one??" Bahaha.
I'm done. Have a peachy day, fellas.
Old 05-14-2015, 08:41 AM
  #50
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
No flak, no way Tim, as Dr. Brown said in Back to the Future, "if you're gonna do somethin you might as well do it with some style." Jett's are about as stylish as you can get.
