OS 50 questions
Old 11-03-2015, 01:59 PM
Calvinman
Default OS 50 questions
Hello again,
Well after getting my 46 apart thanks to help from forum members here I thought I might take apart an old OS 50 I picked up second hand. I figured the bearings might be the same size so if they both need them I may as well buy them at the same time.
I have the motor mostly torn down, but the main bearing remained in the case this time so I am going to heat it and bang it on a piece of wood to try to dislodge it. Can anyone tell me if this motor was any good in its day, it has a ring that is right at the top of the piston and the carb has 5b on it. The front bearing looks and feels shiny new but rear bearing has rust on the cage and feels just a tiny bit rough, the rest of the motor looks to be in very good shape other than part of the fins on the front of the head being ground off from nosing over on an asphalt runway.
thanks,
Calvi
Old 11-03-2015, 06:28 PM
1QwkSport2.5r
1QwkSport2.5r's Avatar
It would help to add the model identifier. It's usually cast into the crankcase on the outside. OS has made hundreds of different models, with some displacements categories having a dozen or more models. Example 50SX, 46SF etc
Old 11-04-2015, 04:08 AM
Calvinman
Hi 1QwkSport, it is an OS MAX.
Old 11-04-2015, 05:22 AM
1QwkSport2.5r
They're all OS Max. There's usually a two-letter model identifier like what I used as examples in my last post. If there are no identifiers, post some pictures of the crankcase?
Old 11-04-2015, 07:53 AM
Calvinman
Here are some pics of the motor case, hope this will help.
ID:	2129015   Click image for larger version
Old 11-04-2015, 08:25 AM
1QwkSport2.5r
Looks like an old FSR. The FSR is said to be the best or one of the best series' of engines OS ever did. They are highly coveted.
Old 11-04-2015, 09:56 AM
Calvinman
Good to know 1QwkSport, thanks. I will definately put new bearnings in it, maybe a new ring too.
Old 11-05-2015, 05:17 AM
Calvinman
Ok one more question, should I source the bearings out at the local hobby shop, local bearing jobber, or online? I found a place called RcBearings.com, has anyone dealt with them or can anyone recommend an online supplier?
Old 11-05-2015, 05:19 AM
1QwkSport2.5r
I use RCBearings.com almost exclusively. Good company to work with and great prices. Boca Bearings is another supplier, but their prices are quite exuberant on a lot of sets.
Old 11-05-2015, 06:13 AM
Calvinman
Thanks again 1QwkSport
Old 11-05-2015, 07:02 AM
1QwkSport2.5r
Sure thing. Good luck!
Old 11-11-2015, 04:58 AM
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
http://www.bocabearings.com/bearing-inventory/1953/enk001-os-engines-fsr-rc-w/mflr-50
Here you go $11.88 and free shipping.
Old 11-11-2015, 06:51 AM
Calvinman
Thanks, I already ordered from RCBearings, I still have a RJL 61 and a couple 46 FX's to do so I may give them a try.
Calvi
Old 11-11-2015, 10:27 AM
JollyPopper
JollyPopper's Avatar
I use RCBearings exclusively. Never had a problem and I figure if it ain't broke, I ain't gonna fix it.
Old 11-11-2015, 12:39 PM
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
It's OK, I've been a Boca guy for 24 years, it's been all good.
Old 11-11-2015, 02:21 PM
spaceworm
Originally Posted by Calvinman
Hello again,...
t has a ring that is right at the top of the piston...
Calvi
Sounds like a Dykes ring? I didn't know OS ever used such a ring. Never to late to learn something/
Sincerely, Richard
Old 11-11-2015, 02:25 PM
spaceworm
Hi Dave. Still trying to get those Farmall pics to you. I can't seem to get them off of the phone onto the PC. PM me your email address, if you choose to, and i will send them that way.
Very best regards.
Sinceerely, Richard
Old 11-12-2015, 06:35 AM
Calvinman
Hi Richard, I will post a pic of the piston later, gotta bring it in from the cold first.
Old 11-12-2015, 06:38 AM
1QwkSport2.5r
Old 11-12-2015, 10:56 AM
jeffie8696
jeffie8696's Avatar
All my FSR engines are wonderful, powerful, reliable works of art
Old 11-12-2015, 11:40 AM
Calvinman
Here a few shots of the piston/ring.
ID:	2130258   Click image for larger version
ID:	2130259   Click image for larger version
Old 11-12-2015, 12:22 PM
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
That's a Dykes ring if ever there was one.
Old 11-13-2015, 10:26 PM
fiery
Looks like it needs replacing
Old 11-14-2015, 05:32 AM
Calvinman
Where do you think I could find one Fiery? I came across someone who sells rings while reading a thread here but forgot to write it down, will have to do a search.
calvi
Old 11-14-2015, 05:49 AM
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Cal, the only Dykes type ring I can find for an OS FRS is for a .45, all the .50 rings I can find are conventional. This one is on E-Bay just search OS 45 Dykes ring.
