OS 52 running issues
Found the problem, dirt in the inlet, looks like it was getting sucked into the HSN opening and causing the problems. Carb is all cleaned out now and ready to run. Tanking the HSN by itself out wouldn't solve it, I had to remove the entire assembly, and thats where I found the crust. I think it may be from the exhaust as it was black and hard like carbon. I flushed everything out while I was at it.
OK after 40 minutes of fiddlin with the needles, I finally got it to run right. That LSN is very very sensitive, just a hair in either direction and it stumbles. I got top end now which I haven't had in quite sometime.
