reactivating 4 cycle 1/4 scale Sig J3
Hi! After a 20+ year lay off I want to get this aircraft flying again. Back then I used an external charging jack while at the field since removing large wing and struts was a hassle. Given risk of fire and balancing jack I am not sure LiPo is the way to go forward. Am I better off going back to NiCad? Do they still make them?
Thanks for any thoughts.
Oh , and , Welcome back to the RC hobby , and Welcome to RC Universe
Thank you again. near term it sounds like dual LIFE's are the way to go. In an effort to start the clearing servo con webs process I bought a 6.0 volt 2000mah NiMH battery yesterday. It took less than 20 minutes at 2 amps to finish with my Hyperion charger. I came across something on line that referenced using 2000/4= 500 charge rate. Another saying 2000/10=200 charge rate. also a reference to the first charge being a very long one (too late?). What say ye?
PS , where this is glow , if there is an on board glow driver , I always prefer those to have their own batteries and not be powered from the RX/servo pack . Like I said earlier this is the only place I still use any NIMH at all , and for glow driver duty (not "mission critical" , in other words) all I do is roast the Hell outta the little single cell till it's good & warm and then that charge lasts the duration of any flying session . Likewise for gassers , I don't run their ignition system off of the RX/servo pack either , and since most ignitions work over a wide range of voltages the two cell LIFE packs (7.2 volts) are perfect for a stand alone ignition power source .
Hopefully someone who knows proper NIMH protocols will fill in a bit of the needed info here ......
