Are ASP .15A and SC .15A exactly the same engines ? And are they any good ?
LHS stocks SC .15A but the figures I have found show that this engine differs slightly from the ASP .15A ...
Are these exactly the same or not ?
Apart from that, are they sweet little engines with reliable carbs ?
Thanks !
Thanks !
You want to have the one with the Blue head. The quality is a little hit and miss like the rest of the engines they make over there. If you're lucky you'll get a good one though. It will spin an 8x4 at around 15000rpm or a 7x5 at around 18500rpm. If you want to use more than 10% nitro, you'll need to add head shims.
