Very nasty OS 46AX
In my experience the bearings in the asp's are the worst ( not as cheap a buy if u factor in the new bearings ) followed by in no particular order saito and OS . I wish I could get $1 or even $7 bearings here in Aus . If I went to the local bearing place a set of 46size would be at least $30-$40 . Its cheaper for me to get from rcbearings in the USA then any place here downunder . Especially if I get enough for a couple of engines at a time .
Look at AvidRC.com. Almost all of their standard bearings are $1USD. If you have a high dollar high-rev engine, then you would need to get bearings with plastic ball retainers.
