OS FS 40 questions on valve lash adjustment
My Feedback: (102)
Since you're going to have the rocker cover off just turn the engine in it's normal direction and watch the intake valve open then close and turn about 120 more degrees. Easier, is to do this with the glow plug out and when the intake valve closes insert a small stick into the glow plug hole and feel the piston come up to the top. There are many other ways.
I grew up south of you in Hookstown.
Thanks I'm having an awfully hard time getting a .003 feller gauge under that rocker. I grew up in Hollidaysburg PA what is the torque values on he head do you know?
Similar devices have been available and are still very available.
Precision Instruments
https://www.amainhobbies.com/gforce-...content=Brands
https://www.kctoolco.com/wiha-28506-...24126.99%20USD
Thanks I will chech they out. I found some used on eBay as well. Do you know how many in pounds is neefed on the ticket nuts? If I find a torque wrench that starts at 10 inch pounds and I want to measure between 10 and 12 is this too big.
this is a os fs 40
this is a os fs 40
My Feedback: (102)
Gary would you please clarify this for me: (values from 2 to 8 KGF.M), it appears to me that it should read KGF.MM. Thanks
Never seen a kgf.mm spec. More likely they left out the decimal points on the pounds force foot side.
.2 lbf.foot equals 1,44 kgf.m and .8 kgf.m equals 5.78 lbf.ft
1 kgf.m = 7.233014 lbf.ft
My Feedback: (102)
Don't read this just yet: OK read it now
According to this: https://www.translatorscafe.com/unit...-force%20inch/
2 KGF.M===2,777 oz inch, 2 KGF.MM===2.777 oz inch. which seems more realistic.
The GForce 6 in 1 Torque Driver Set is a revolutionary product, developed for drivers that demand perfection. This driver allows the user to set specific torque values from 2 to 8 KGF.M, so once you determine the correct value for each screw, you can tighten it to the exact same tension every time. This will help to prevent stripped screws, tweaked components, and adds a level of precision that the RC world has never known.
Edit above: I transposed the units
.8kg.m equals kg.f equals 1.44 lbf.ft
That would make the range in Lb/Ft 1.44 to 5.78
The kgf.mm makes perfect sense for small fasteners in that case Dave.
Hopefully the links helped...
