Saito 170r3 fix help
Reply
Old 08-06-2018, 09:44 AM
smkrcflyer
smkrcflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Saito 170r3 fix help
I recently purchased a 170r3. After receiving it I noticed one of the intake tubes was cracked almost all the way around. I have a new one on the way. What's the easiest way to replace this?
smkrcflyer is online now
Old 08-06-2018, 12:56 PM
Hobbsy
My Feedback: (101)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The way it looks you need to remove the bolts that hold the back plate to the crankcase, back all three intake tubes out of their respective heads, replace the bad one, and put it back together. Someone may know a simpler way.
One other hint, make sure the little O-rings are in the head and push the tube into the O-ring being gentle and careful.
Hobbsy is online now
Old 08-07-2018, 02:23 AM
smkrcflyer
smkrcflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you.
Old 08-07-2018, 02:34 AM
Hobbsy
My Feedback: (101)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Like this.
Another hint, if you remove the black mounts, when replacing them, set the engine on a hard flat surface while doing the final tightening. That way the mounting tabs that bolt to firewall will be perfectly even.
Old 08-07-2018, 02:52 AM
Jesse Open
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also, lube the O-rings and tubes with a bit of petroleum jelly or silicone grease before assembly.
Jesse Open is online now
Old 08-07-2018, 03:02 AM
smkrcflyer
smkrcflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Will do. I will let you know how it goes. Should have the parts Saturday.
Old 08-07-2018, 01:50 PM
blw
blw's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had a FA-170R3, so I know this is a bit tricky to do. I don't have the engine anymore so I can't duplicate the job for you here. The engine is now somewhere in Sweden.
blw is offline
Old 08-07-2018, 04:13 PM
smkrcflyer
smkrcflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a few other questions for you guys about this engine. Its going on a Great Planes PT-17.
What prop?
What fuel? %NITRO and oil.
Maintenance? What to do with it after a day of flying and at the end of the season.
Old 08-07-2018, 04:31 PM
Hobbsy
My Feedback: (101)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Saito FA-170R3
Here is a test of the 170 R-3, Chianelli is not the best tester, he hits the high spots.
Old 08-07-2018, 04:43 PM
smkrcflyer
smkrcflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Hobbsy View Post
Saito FA-170R3
Thank you.
Old 08-10-2018, 10:08 AM
smkrcflyer
smkrcflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
New intake tube is in and all looks good. The weld is broken on one of the exhaust tubes where it goes into the main ring. I'm taking it to a local shop to see if they can fix it. The main part of the ring that connects to each of the cylinders is on the front of the engine. I haven't seen this on any of the other Keleo exhaust rings.
Old 08-11-2018, 05:29 AM
Linkan2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
try lifting the cylinder
I fly with 10% oil 10% nitro.
And now the 17x8 prop 16x10 works.
my 170 is sitting in a Greate lake
Linkan2 is offline
Old 08-12-2018, 07:03 PM
blw
blw's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Props? I seem to remember those in the 15" range were a good place to start. I still have some new APCs I could mail up to you.
blw is offline
