Magnum .91 2 stroke manual or parts explosion
Reply
Old 08-14-2018, 11:00 AM
edolson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Magnum .91 2 stroke manual or parts explosion
Looking for the items in the title. I've got one of these engines and the carb barrel won't budge. Just want to make sure I take it apart correctly.
Ed
edolson is offline
Old 08-15-2018, 03:16 AM
Jesse Open
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Maybe these folks can help:https://www.justengines.co.uk/acatal...S--Spares.html
Exploded diagram for 2 stroke/cycle .91:ASP91exp.pdf
Heat and penetrating oil help, don't forget the HEAT.
Last edited by Jesse Open; 08-16-2018 at 03:00 AM. Reason: Two stroke info to replace four stroke
Jesse Open is offline
Old 08-18-2018, 07:41 AM
H5606
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Another vote for heat.
I keep all my engine boxes - have an early Magnum .91A (round head) - the instruction manual is a single sheet for both the .91 and 1.08 - exploded view is sparse and only shows carb as a complete assembly.
The pdf provided by Jesse Open above is more informative than what I have and may be similar if not identical to the carb.
I have mistaken congealed castor for rust or corrosion resulting in seized piston and crank and/or carb barrel.
What I've done:
If the engine is not attached to any structure, wait till wife leaves to go shopping, preheat oven to 250F, ensure no plastics attached to engine, place in oven for 10-15 minutes, remove from oven with heavy leather gloves and try moving carb barrel. While at it, attach wood prop and turn over to check/feel compression and bearing races. If engine is attached, careful use of heat-gun to direct heat where necessary has been used with success. Oil up with Marvel Mystery oil while warm and parts are free to move.
H5606 is offline
Old 03-23-2019, 02:09 PM
Bill Diedrich
Bill Diedrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you are still looking for a new carb for your Magnum 91 2-stroke engine you can find one here:
https://www.mikegoesflying.com/produ...-stroke-parts/
Bill Diedrich is offline
