Exhaust gasket. OS 55AX
I am getting back into glow aircraft after last dabbling 30 years ago. I have bought a new OS 55AX and am about to start running it in on the bench.
I was a little surprised to find there is no mention in the instructions of fitting any kind of gasket in between the head and the exhaust. There is a warning that *if* a silicone sealant is used care must be taken not to allow the possibility of any entering the engine.
Do I need to add sealant or a gasket, or, can I just run it with metal against metal?
Run it metal to metal or use a thin film of RTV (sensor safe!!) between the engine and muffler. I use RTV all the time. Never a worry if a little oozes in. Just make sure the rtv cures before running the engine. Otherwise it might blow out and leak.
I’ll tell you, even the highest quality engines leak between the exhaust port and muffler. I would always recommend a thin layer of RTV on the muffler. It’s not rocket science and it does make a significant difference most often. YMMV, but probably not by much.
I take a fine single cut file and take a few swipes with my thumb pushing in the centre so there is no rocking, and it just takes the top of the machining marks off. I don't use a gasket. I had to LOL at Qcksport pouring silicone down the venturi. I don't mind a 'little' mess but have not noticed any. I have a few swap meet engines with some silicone stains that don't like to completely come off. Sparingly I guess.
