Bearings-Brass cage vs steel cage
Reply
Old 03-30-2004, 04:07 AM
Cajuncharley
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bearings-Brass cage vs steel cage
What are the pros and cons of the use of brass cages vs steel cages on rear bearings, such as in a Saito 1.80. I would guess brass will not rust as steel does, but probably not as strong as steel. I note most bearings have steel cages. Is this primarily because of cost? Or because it is more durable.
Cajuncharley
Cajuncharley is offline
Old 03-30-2004, 06:46 AM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Bearings-Brass cage vs steel cage
I tend to think that a steel cage can take more rpm... but since that doesn't matter at the rpm your 1.80 runs both are the same.
Brass rusts too... it doesn't rust like steel though... instead of becoming brown it becomes green... but it rusts all the same...
Rudeboy is offline
Old 03-30-2004, 07:17 AM
DarZeelon
DarZeelon's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Charles, Winibald,
Brass has a lower tendency to rust, but its more positive attribute is a lower friction coefficient with the steel bearing balls.
Stainless steel bearing have SS retainers and are less prone to rust, but are weaker as far as load capacity is concerned.
There are also retainers made from phenolics, or polymite plastic, which obviously don't corrode.
DarZeelon is offline
Old 03-30-2004, 07:32 AM
jaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi!
Brass (doubt it is brass really,plated maybe) or steel caged bearings is normal in modelengines but better still is bearings with plastic retainers because of less damage to the engine if the retainers brake.
What is important in model engines is to have a bearing that turns easily...standard ballbearings are not the best suitable for modelengines! Better is to get C3 or C4 bearings ( C3 or C4 is a bearing with more play between the balls and the inner and outer shell).
Nowadays there is even ceramic bearings available and they are even better but much more expensive than ordinary steel ballbearings.
I think Boca bearings has them.
Regards!
Jan k
Sweden
jaka is offline
Reply
Display Modes
