Engine Cleaning
Engine Cleaning
I've stumbled across what appears to be an outstanding product for cleaning crud from engines, both external and internal. The stuff is "Power Dissolver" from Dawn (available at the local grocery store), it's designed to be used on cooking utensils, grills, etc. and is washed off with water.
I decided to try it on the internals of an engine that was pretty cruddy. The directions say to spray it on and wait 10-15 minutes before washing it off with water. I found that it worked in a minute or two, a light brushing with a bristle brush removes carbon from the piston top, combustion chamber, and exhaust valve. A quick rinse with water and blow dry resulted in shiny, new appearing parts.
It has a mild citric odor that's not unpleasant. The label describes the contents as a "biodegradable alkaline cleaning agent", so I would expect that it might darken aluminum / brass parts if soaked too long.
Earl
Earl
