Tower Hibbies .75 - too noisy
Reply
Old 06-28-2003, 10:46 PM
Mikes machines
Mikes machines's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Tower Hibbies .75 - too noisy
You might be able to braze a piece of thin sheet metal with holes drilled in it to the center through bolt to act as a baffle
Mikes machines is offline
Old 08-04-2004, 02:09 AM
rcairplanenut
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Tower Hibbies .75 - too noisy
hi there i have 6 tower engines, i would try steel wool in the muffler, and or diffrent props. props can contribute to hi DB #
SGG
rcairplanenut is offline
Old 08-04-2004, 07:07 AM
Stripes
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Bisson muffler is specified to work with both the Tower 75 and the GMS 76. Makes sense because both engines are made by the same maker and both have the same backward muffler bolt attachment. So the exaust sizes must be the same.
http://www2.towerhobbies.com/cgi-bin...?&I=LXGBL0&P=0
Therefore it makes sense that the GMS standard muffler would fit the Tower 75 just fine and be quieter because it is of a more conventional design than the Tower.
http://www2.towerhobbies.com/cgi-bin...?&I=LXEHA2&P=Z
If you try this please post back as I have a Tower also and would like to know how it works out.
Stripes is offline
Old 08-04-2004, 09:38 AM
Sport_Pilot
Sport_Pilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is the Brison muffler actual quite? Thought those were almost useless as a muffler.
Sport_Pilot is offline
Old 08-04-2004, 11:12 AM
smokingcrater
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hate to interrupt. But has anybody any ideas how to quieten my ***!!!! Tower .75 ....?
Interesting though the conversation is.
this thread just went completely off course fast!! anyway, try putting some fiberglass material inside the exhaust. (start small and work your way up.) Use the fiberous stuff, not the cloth like material.
also, if you aren't overly concerned about power, just set up your linkages to go a little below full throttle. you might not need it, and that might be enough to be at the noise level permitted by your field.
also, I wasn't aware that AMA had any noise restrictions? anyone have a document at modelaircraft.org that says it?
smokingcrater is offline
Old 08-04-2004, 11:54 AM
  #31
Ed_Moorman
Ed_Moorman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When the pattern guys used 2-strokes, they used long tuned pipes and higher pitch props to keep the rpm below 10,000 and met 94db pretty easily. And they gained power. It's something to think about.
Ed_Moorman is offline
Old 08-04-2004, 06:23 PM
  #32
Stripes
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Sport_Pilot
Nobody cares if the Bisson is quiet. The web site says the size is the same. Use of the GMS standard muffler will lower the noise.
Stripes is offline
Old 08-04-2004, 10:48 PM
  #33
jschenck
My Feedback: (23)
jschenck's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Tower Hobbies .75 - too noisy
I'll bet my Fox-74 is louder than your TH-75 !! :-)
Put a steeper pitch prop (not a longer one), like try an 11x9 or even an 11x10 with rounded style tips, that is, not sharp corners. The idea is to reduce the tip speed, which is where a lot of noise comes from. Props get very noisy when the tips go supersonic.
Also, go to an automotive parts store or LHS and get a foot of silicone tubing. Zip tie it to the end of the muffler and attach the tubing to the underside of the fulelage. Not only will it be quiter, but it will get th oil/gunk away from most of the aircraft.
As a third step, make the after-muffler suggested in one of the previous steps and you'll have an airplane that will sound like a high performance electric!
jschenck is offline
