Saito 100 vs 91
Old 07-18-2004, 11:46 AM
flipstart
Default Saito 100 vs 91
Is the Saito 100 that much more powerful than the 91? I plan on building a Funaero Albatross and kit calls for a 91 but was considering a 100, wondered if it was worth the $50 extra cost. Other than cost both engines seem to be about same size and weight.
Any opinions or experience on this subject? Thanks Flipstart
Old 07-18-2004, 11:57 AM
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Default RE: Saito 100 vs 91
The 100 is considerably more powerful than the .91 using a 15x6 or 14x8 as opposed to a 14x6 for the .91, the 100 is very nearly as strong as the 120.
Old 07-18-2004, 12:15 PM
outssider
My Feedback: (23)
the saito 100 has virtually replaced the 91 and rendered it obsolete
much like the ys110 replaced the ys 91
and the ys140 sport replaced the ys120
Old 07-18-2004, 10:31 PM
ukrconsul
I have Saito 91 but not 100.
The specification charts say that the power difference between them is only 0.1 hp (1.7hp against 1.8hp)
At the same time there are a lot of people here in RC Online who has trouble with Saito 100.
The 91 will also turn 15x6 or 14x8 at reasonable rpm.
Old 07-18-2004, 11:50 PM
krayzc-RCU
My Feedback: (31)
the 100 use more fuel and turns about 600-800 more per prop than the 91 its a beast.. but i perfer a 91
Old 07-19-2004, 10:07 AM
futaba1024
Hi.
From my experience, it highly debatable whether the 100 is much better than the 91, for a start the 100 at 610gms against 550gms for the 91, this is my own measurements on a calibrated digital scale, so there is a weight difference in spite of what the specs say, also the 100 is quite a bit taller and wider than the 91.
As regards power from my own prop tests the 100 is only giving about .1hp more than the 91, imho the 91 is about the best power to weight ratio in it's class and I think in the near future we will see a new Saito based on the 100 cank case at around 115-120 capacity and that will probably be a real cracker.
Cheers.
Old 07-19-2004, 12:47 PM
flysforfun
This is so NOT true! Take a look at the other messages. Let me summarize:
- the 91 is smaller than the 100.
- the 91 weighs less than the 100
- the 91 costs less than the 100.
- the 91 is less power than the 100 (although only marginally so).
thus- if you need a lightweight & powerful 91, get the 91. If you absolutely need extra power, pay the extra money , weight and size, and get the 100.
BTW- I have both a Saito 91 and 100.
Old 07-19-2004, 02:02 PM
futaba1024
Flysforfun.
As you can see I am with you on this one, I also have 2 91's and 1 100, of course the interesting comparison is the Saito91 and YS63 which I have also.
Cheers.
Old 07-20-2004, 10:44 PM
SA Flyer
SA Flyer's Avatar
This has been interesting so far. I too have been considering a 100, but the current threads on problems have yet to convince to get one.
I have a question for y'all. (Yes, SA means San Antonio. Excuse me, please).
Do you guys use 15% Helicopter fuel in your Saitos? What fuel brand do you use and what nitro percentage? I'm curious.
thanks,
SA Flyer
Old 07-20-2004, 11:13 PM
krayzc-RCU
My Feedback: (31)
satio love nitro i run both 15/30 on there
Old 07-21-2004, 09:08 AM
jzinckgra
jzinckgra's Avatar
Would 5% nitro be ok also to use on my 91?
Old 07-21-2004, 09:47 AM
krayzc-RCU
My Feedback: (31)
yeah it will run like a 65 satio on 15% u really need to feed the satio 15% yeah it will run on less just not be the motor u will think it should b
Old 07-21-2004, 02:06 PM
NOVAflier
My Feedback: (21)
NOVAflier's Avatar
What problems? I have owned 2 100's and have loved both of them. Got both to idle around 1800 rpms and both always started right up with a flip...
