Heat and Engines
CA
Heat and Engines
As it gets hotter here.... average 90-100 these days, Im having more and more trouble keeping my glow engine running without overheating. I have the Evolution .46nt, with an 11.5x4 prop, in the Hanger 9 FuntanaS .40. I already removed the cowling around the engine, but it still gets very hot. would a different prop help? or maybe different fuel? or some tricky setting with the muffler or needle valve that I dont know about yet? I cant imagine what people in places like Phoenix do to keep their planes running.... have a Large air conditioned building? Any ideas would be greatly appriciated
RE: Heat and Engines
A different prop might be the answer as well. The prop your using seems to be flying the model well for you, it may add a bit of a load in the heat. Try someting different to see. You may add an extra bit of oil to the fuel as well.
AZ
In AZ some counties daily averages are 105 - 111 deg. daily for the next couple of months. Try a small increse in your oil content and run the engine richer. Fuel is one of the principal ingredients in engine cooling.
BadSplice,
Richen up the engine 200-300 rpm an the top end and make shore that you fuel is in the 20-25% oil range. It is the oil that helps carry the heat away. Maybe you are a tad lean on the engine. Gets that hot here in the Summer only Winter at the moment around 4deg C at the present. Winter Sucks.
Cheers.
Cheers.
The heat problem is that the hot air is less dense than you are used to. To get the fuel/ air ratio where your engine runs best, you end up setting the engine leaner. Adding oil cuts down the proportion of combustabiles in your fuel. In essence it leans out the engine for you, whilst adding lubrication.
Jim
Jim
CA
Thanks for the tips Less nitro and more oil in the fuel make sense... Ive been messing with the mixture, and it seems to heat up a lot either rich or lean, but it dies if its too rich. I also tried a 10x6 and an 11x4 prop. the 11x4 seemed the best, nest time I'll try the 11x5 also. Is the oil easy to come by? I suppose I could always buy some new fuel for summer but just cracked open a case of the 15-18 kinda hate to buy more
BadSplice,
If the 15-18 is the oil content of the fuel you are using there an't enough oil there. At least 20% allways.
Cheers.
Cheers.
My Feedback: (22)
MO
As the temp rises the ignition point in a glow engine advances. When this happens the engine starts to run hotter and the ignition advances even more. Less nitro will retard the ignition point. More oil also retards the ignition point. Both are good for a hot running engine. Of course a richer mixture will allow the engine to also run cooler. There is one more element that know one mentioned, the glow plug. Put a colder plug in this thing and your problems should diminish. A colder plug will retard the ignition point.
CA
I was expecting that the nitro content would affect the engine.... But I handt considered the oil or the plug. Im running an OS #8 plug right now, can anyone suggest a cooler one? Also, how forgiving is the engine to different oils? Do you have to use castor? or is that just the best one?
BS:
Synthetic oils give essentially no cooling, they mostly burn, but not quite so hotly as the methanol. Castor oil doesn't burn, it absorbs the heat and carries it out the exhaust.
To a point more nitro runs cooler, but only because you're taking more methanol in along with it.
Unless I'm mistaken the OS #8 is their hottest plug, the A3 is the colder one.
Bill.
Bill.
OS Glow plug info:
http://www.osengines.com/accys/glowplugs.html
The A5 plug is colder than than the A8 according to the above info.
There is also one called an "R5" that is even colder...
Yes the more oil sounds rite but I don't think less Nitro won't running more nitro give you more power at a richer setting?
Hi!
How do you know your engine runs hot?
When I was in the states in -95 competing in the worldchamps in pylonracing in Muncie Indiana it was real hot, most days around 40 degrees celsius (around 90-100F). And wee ran our 6,5cc Nelsons and IR pylon engines on 80/20 fuel with rpm around 30000 without probems, in our tighly cowled airplanes.....or not so tighly sometimes.....
We used "Rich's Brew" FAI fuel.
Sport engines have no problem of coping with these temperatures (40degrees C) as long as the engines are not set too lean....cowls or no cowls ....so have you opened the highspeed needle and checked if your engine runs OK then?!
11.5x4 APC will be no problem for your engine if you fly at sea level. Also try a APC 11x6.
5%-10% nitro is mostly enough, 15% nitro is overkill and some engine on the market doesn't like that much nitro.
See to that you use good fuel.....best to blend your own so you know what you get.
And use a good sport glowplug like an OS 8 or an Enya 3 plug. Other plugs will work too but these to are the best for sport flying (Not for best rpm though).
Regards!
Jan Karlsson
Sweden
Regards!
Jan Karlsson
Sweden
Jan makes a good point. I know it sounds silly, but exactly what is your definition of "running hot"? Is the engine sagging/detonating and loosing power in the air, or when you say it is running hot, do you mean that it is very hot to the touch after you shut it down? People need to understand that these engines can and do run quite happily at temps that will easily take your skin off! I used to fly an old YS .61 Long stroke in pattern competition that would run like a champ all day long in the Oklahoma and Texas summer heat (100 F+), but after shutting it down at the end of a flight, if someone picked it up wrong and got their arm against the cylinder head...they ended up with a YS brand in their skin for some time!
This is not to say all the suggestions about extra oil, and/or castor is a bad idea, as they are not, I'm just saying that some people don't understand the kind of temps these engines can make it hot weather. As long as the prop is turning, and the engine running, the air blowing across the fins and spent oil in the exhaust are carrying away a lot of heat. But once shut down, the trapped heat inside the engine can actually raise the external engine temps to some pretty scary levels for a few minutes after a flight.
Just something to think about.
ND
great advice RLDIII!! unless you are actually measuring temp, don't guess that it might be hot. (unless you see symptoms of it...) as others have mentioned, the difference between 75 degrees and 100 degrees basically makes no difference to an engine, since you are already so much hotter then that.
Good point. Someone here once considered their engine to be overheating because their spit sizzled. But water boils at only 212 degrees and our engines run hotter than that. During the spring the engine could easily cool below 212 by the time you walk out and bring it back. But it takes longer to cool down in the summer.
